StarTech.com Multiple Video Input with Audio to HDMI Scaler Switcher - HDMI / VGA / Component
Quicklinx: 8FJ1WS00 Mfr#: VS721MULTI
£350.24 ex VAT
£420.28 inc VAT
Share an HDMI display between multiple analog or digital video sources (e.g. VGA, Component, S-Video, Composite, HDMI). The VS721MULTI Multiple Video Input to HDMI Switcher enables users to switch between 7 different audio-video sources to a single HDMI-equipped display.
This versatile scaler/switcher is the perfect solution for combining and scaling analog video sources (RGB/YPbPr/YCbCr) with your digital HDMI display, eliminating the cost of upgrading individual components (i.e. DVD player, PC, VCR, etc.).
An all-in-one multimedia solution, the video converter/switcher includes support for full high definition 1080p video resolution as well as digital and analog audio. Plus, the switch features RS232 remote serial control, and includes a convenient IR remote control for switching between video sources.
StarTech.com Multiple Video Input to HDMI Switcher - HDMI / VGA / Component (VS721MULTI) - video/audio switch - 7 ports
Video/audio switch - 7 ports
Subtype
HDMI / component video / S-Video / VGA /audio
HDCP compliant
AC 120/230 V
17.3 cm x 38.4 cm x 4.5 cm
1.8 kg
Microsoft Windows Server 2008 R2, Microsoft Windows Vista / XP / 7 / 8, Windows 10 (32/64 bits)
North America, United Kingdom, Europe
P/N: SVA12M2NEUA, SVA12M5NA
Enclosure Type
Desktop
Subtype
Max Resolution
1920 x 1200
HDCP compliant
1 x component video input RCA x 3 , 1 x VGA input HD-15 , 3 x HDMI input , 1 x composite video input RCA , Audio / video: 3 x RCA , 1 x audio input mini-jack , Video: 1 x S-video input , 1 x HDMI output , 1 x serial (RS-232) DB-9
External power adapter
AC 120/230 V
Remote control
1 x serial cable
Mounting Kit
Included
FCC, RoHS
17.3 cm
38.4 cm
4.5 cm
1.8 kg
70 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
85 °C
8FJ1 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.37
8FJ1 StarTech.com 2 Port USB HDMI KVM Switch with Audio and USB 2.0 Hub In Stock £177.08
8FJ1 StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.94
8FJ1 StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.82
8FJ1 StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.74
8FJ1 StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £5.00
8FJ1 StarTech.com Conference Table Connectivity Box – HDMI / VGA / Mini DisplayPort to HDMI Output In Stock £208.11
8FJ1 StarTech.com 2x1 HDMI VGA to HDMI Converter In Stock £128.61
8FJ1 StarTech.com DC Power Adapter - 12V, 2A In Stock £12.66
8FJ1 StarTech.com DC Power Adapter - 12V, 5A In Stock £41.16
