StarTech.com Multi Stream Transport Hub – DisplayPort 1.2 to Triple Head DisplayPort MST Hub
Quicklinx: 9FSWWS00 Mfr#: MSTDP123DP
Hurry, only 1 left in stock!
£73.43 ex VAT
£88.11 inc VAT
Use this multi-stream transport hub to connect three DP monitors to a single DP 1.2 port. This MST hub lets you connect three monitors to your DisplayPort (DP) 1.2 equipped Windows laptop or desktop.
The newest generations of computers are more portable than ever, which often means that you're left with fewer video outputs and smaller integrated screens. This MST hub solves both of these problems by letting you connect three additional displays to your computer, which makes multitasking much easier.
With the MST hub, you can use DisplayPort video adapters and cable adapters that enable you to connect HDMI, VGA or DVI displays. This ensures your MST hub will be compatible with virtually any television, monitor or projector. This MST hub is VESA and DisplayPort certified to support DP 1.2 enabled systems, for seamless integration with your existing video equipment.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display giving you the freedom to multitask and increase your productivity. You can also mirror the same image onto multiple displays for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. This unprecedented performance makes MST perfect for high-resolution applications such as graphic design, gaming and medical imaging.
Note: When using a DisplayPort 1.1 video card the MSTDP123DP will act as splitter, automatically mirroring your video source across all displays. Resolution limitations apply.
The MSTDP123DP supports plug-and-play installation for a hassle-free setup.
StarTech.com 3 Port DisplayPort MST Hub - 4K 30Hz - DisplayPort to DisplayPort Multi Monitor Splitter for 3 DP Monitor Setup (MSTDP123DP) - video splitter - 3 ports
Video splitter - 3 ports
Plastic housing
AC 100/230 V
7.8 cm x 38.6 cm x 2 cm
99 g
3-year warranty
P/N: SV231DPU34K, SVA5N3NEUA
Enclosure Type
Desktop
Max Resolution
2560 x 1600
Plastic housing
3 x DisplayPort , 1 x DisplayPort
External power adapter
AC 100/230 V
FCC, RoHS
7.8 cm
38.6 cm
2 cm
99 g
Shipping Width
22.9 cm
Shipping Depth
15.5 cm
Shipping Height
5.5 cm
Shipping Weight
409 g
Limited warranty - 3 years
45 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
9FSW StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £15.21
9FSW StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.18
9FSW StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.06
9FSW StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £15.24
9FSW StarTech.com Multi Stream Transport Hub – DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £73.43
9FSW StarTech.com Multi Stream Transport Hub – Mini DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £80.21
9FSW StarTech.com MST Hub - mDP to 2x DP In Stock £49.45
9FSW StarTech.com MST Hub - 4-Port DisplayPort In Stock £120.91
9FSW StarTech.com DisplayPort to 3x HDMI MST Hub In Stock £107.65
9FSW StarTech.com DC Power Adapter - 5V, 3A In Stock £10.83
Price Range Ex VAT: 50 - 100
