StarTech.com mSATA to SATA HDD / SSD Adapter – Mini SATA to SATA Converter Card
Quicklinx: 964YWS00 Mfr#: MSAT2SAT3
Type: Adapter
More than 50 in stock
£12.03 ex VAT
£14.43 inc VAT
Turn an mSATA host connection into a standard SATA port. The MSAT2SAT3 mSATA to SATA adapter enables you to connect a standard SATA drive to an available mSATA port.
The adapter improves system capacity by enabling an mSATA port to host a larger SATA hard drive (tested up to 4TB). For guaranteed compatibility and performance the adapter is compliant with SATA I/II/III revisions, allowing for transfer speeds up to 6Gb per second.
StarTech.com mSATA to SATA HDD/SSD Adapter - Mini SATA to SATA Converter - storage controller - mSATA - SATA 6Gb/s
Storage controller - internal
Bus Type
SATA 6Gb/s
mSATA
Data Transfer Rate
6 GBps
Supported Devices
Hard drive, solid state drive
Channel Qty
1
3 cm x 5.1 cm x 0.8 cm
60 g
Host Bus
SATA 6Gb/s
Storage Controller
mSATA
Data Transfer Rate
6 GBps
Supported Devices
Channel Qty
1
1 x - mSATA
1 x SATA 6Gb/s - 7 pin Serial ATA
Mounting Kit
Included
RoHS
3 cm
5.1 cm
0.8 cm
60 g
5 °C
50 °C
20 - 80%
Type: Adapter
Price Range Ex VAT: 0 - 50
