StarTech.com mSATA to SATA HDD / SSD Adapter – Mini SATA to SATA Converter Card
Quicklinx: 964YWS00 Mfr#: MSAT2SAT3
Type: Adapter
Hurry, only 2 left in stock!
£12.79 ex VAT
£15.34 inc VAT
Turn an mSATA host connection into a standard SATA port. The MSAT2SAT3 mSATA to SATA adapter enables you to connect a standard SATA drive to an available mSATA port.
The adapter improves system capacity by enabling an mSATA port to host a larger SATA hard drive (tested up to 4TB). For guaranteed compatibility and performance the adapter is compliant with SATA I/II/III revisions, allowing for transfer speeds up to 6Gb per second.
  • Reliable connection
    This adapter enables a link between mSATA drives and SATA interfaces, expanding storage options in various systems.
  • Versatile compatibility
    Designed to support both hard drives and solid state drives, making it a suitable option for different storage needs.
  • Efficient data transfer
    With a data transfer rate of 6 Gbit/s, this adapter ensures performance for demanding applications.
  • Easy installation
    The included mounting kit simplifies the installation process, allowing for quick setup without additional purchases.
  • Resilient environmental performance
    Able to operate within a temperature range of 5°C to 50°C and humidity levels of 20 to 80%, ensuring reliable functionality.
StarTech.com mSATA to SATA HDD / SSD Adapter - Mini SATA to SATA Converter Card - mSATA to SATA 2.5/3.5 Hard Drive Adapter Converter Card (MSAT2SAT3) - storage controller - mSATA - SATA 6Gb/s
Storage controller - internal
Bus Type
SATA 6Gb/s
mSATA
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Channel Qty
1
3 cm x 5.1 cm x 0.8 cm
60 g
Host Bus
SATA 6Gb/s
Storage Controller
mSATA
Data Transfer Rate
6 Gbit/s
Supported Devices
Channel Qty
1
1 x - mSATA
1 x SATA 6Gb/s - 7 pin Serial ATA
Mounting Kit
Included
RoHS
3 cm
5.1 cm
0.8 cm
60 g
5 °C
50 °C
20 - 80%
964Y StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
964Y StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable In Stock £5.50
964Y StarTech.com 12in Latching SATA Cable In Stock £6.16
964Y StarTech.com 12in SATA Serial ATA Cable In Stock £5.00
964Y StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F In Stock £6.16
964Y StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure In Stock £29.96
964Y StarTech.com mSATA to SATA HDD / SSD Adapter – Mini SATA to SATA Converter Card In Stock £12.79
964Y StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £15.57
964Y StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £18.13
964Y StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter In Stock £14.65
964Y StarTech.com x4 PCI Express to M.2 PCIe SSD Adapter In Stock £18.76
964Y StarTech.com M.2 to U.2 Adapter In Stock £23.11
964Y StarTech.com x8 Dual M.2 PCI Express SSD Adapter - PCIe 3.0 for PCIe NVMe In Stock £132.24
Type: Adapter
