StarTech.com mSATA Raspberry Pi Adapter
Quicklinx: CQ2CWS00 Mfr#: PIB2MS1
Connect an mSATA drive to your development board, to increase its data storage capacity. Increase the data storage capacity of your Raspberry Pi or other development board, by connecting it directly to a an mSATA drive. Perfect for custom projects and applications, this USB to mSATA converter supports all models of Raspberry Pi as well as other development boards.
This convenient USB 2.0 mSATA converter lets you overcome data storage limitations by enabling you to connect an mSATA drive through your board's USB-A port.
The USB to mSATA converter integrates seamlessly with your existing development board. It's the perfect addition for development-board based applications such as surveillance, media players and servers, digital signage and IoT/automation solutions. It allows you to utilize your mSATA drives with your development board, and take advantage of the small form factor of mini-SATA, ideal for applications with space limitations.
Compatible with SATA I, SATA II and SATA III drives, the converter is easy to install and doesn't require any device driver installation. It comes with a USB cable and all mounting accessories, including standoffs, so integrating it with your Raspberry Pi is fast and easy.
StarTech.com USB to mSATA Converter for Raspberry Pi and Development Boards - USB to mini SATA Adapter for Raspberry Pi (PIB2MS1) - storage controller - mSATA - USB 2.0
Storage controller - internal
Bus Type
USB 2.0
Red
mSATA
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Channel Qty
1
5.5 cm x 6.5 cm x 1.1 cm
18.2 g
Host Bus
USB 2.0
Red
Storage Controller
mSATA
Data Transfer Rate
6 Gbit/s
Supported Devices
Channel Qty
1
Renesas µPD720231A
1 x mSATA - mSATA
1 x USB 2.0 - mini-USB Type B
1 x micro-USB cable
USB powered
Mounting Kit
Included
MTBF
5,077,966 hours
5.5 cm
6.5 cm
1.1 cm
18.2 g
5 °C
50 °C
15 - 90%
CQ2C StarTech.com 6in Micro USB Cable - A to Micro B In Stock £4.99
CQ2C StarTech.com mSATA to SATA HDD / SSD Adapter – Mini SATA to SATA Converter Card In Stock £12.79
CQ2C StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £18.13
CQ2C StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter In Stock £14.65
