Connect an mSATA drive to your development board, to increase its data storage capacity. Increase the data storage capacity of your Raspberry Pi or other development board, by connecting it directly to a an mSATA drive. Perfect for custom projects and applications, this USB to mSATA converter supports all models of Raspberry Pi as well as other development boards.
This convenient USB 2.0 mSATA converter lets you overcome data storage limitations by enabling you to connect an mSATA drive through your board's USB-A port.
The USB to mSATA converter integrates seamlessly with your existing development board. It's the perfect addition for development-board based applications such as surveillance, media players and servers, digital signage and IoT/automation solutions. It allows you to utilize your mSATA drives with your development board, and take advantage of the small form factor of mini-SATA, ideal for applications with space limitations.
Compatible with SATA I, SATA II and SATA III drives, the converter is easy to install and doesn't require any device driver installation. It comes with a USB cable and all mounting accessories, including standoffs, so integrating it with your Raspberry Pi is fast and easy.
- StarTech.com USB to mSATA Converter for Raspberry Pi and Development Boards - USB to mini SATA Adapter for Raspberry Pi (PIB2MS1) - storage controller - mSATA - USB 2.0
- Storage controller - internal
- Bus Type
- USB 2.0
- Red
- Interface
- mSATA
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive, solid state drive
- Channel Qty
- 1
- 5.5 cm x 6.5 cm x 1.1 cm
- 18.2 g
- 2-year warranty
- Host Bus
- USB 2.0
- Red
Storage Controller
- Interface
- mSATA
- 6 Gbit/s
- Supported Devices
- Channel Qty
- 1
- Processor
- Renesas µPD720231A
- 1 x mSATA - mSATA
- Connections
- 1 x USB 2.0 - mini-USB Type B
- Cables Included
- 1 x micro-USB cable
- USB powered
- Mounting Kit
- Included
- MTBF
- 5,077,966 hours
- Limited warranty - 2 years
- 5.5 cm
- 6.5 cm
- 1.1 cm
- 18.2 g
- 5 °C
- 50 °C
- 15 - 90%
