The SFP-10GBASE-LRM-ST is an 10 GMSA compliant fiber SFP+ transceiver that's designed, programmed and tested to work with 10GBase-LRM compatible MSA switches and routers. The SFP+ transceiver module supports a maximum distance of up to 200 m (656 ft) and delivers dependable 10 GbE connectivity over fiber cabling.
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP+ modules and direct-attach SFP+ cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com MSA Uncoded Compatible SFP+ Module, 10GBASE-LRM, 10GbE Multi Mode (MMF) Fiber Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC Connector, 200m, 1310nm, DDM, Mini GBIC Module - Lifetime Warranty (SFP-10GBASE-LRM-ST) - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-LRM
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 200 m
- 5.84 cm x 1.39 cm x 1.37 cm
- 21 g
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-LRM
- 10GbE
- 10 Gbps
- 1310 nm
- 200 m
- Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 10GBase-LRM - LC multi-mode female x 2
- MTBF
- 646,156,559 hours
- MSA
- 1 Watt
- 5.84 cm
- 1.39 cm
- 1.37 cm
- 21 g
- Shipping Width
- 9 cm
- Shipping Depth
- 11.5 cm
- Shipping Height
- 3.1 cm
- Shipping Weight
- 50 g
- Limited warranty - lifetime
