StarTech.com MSA Compliant 10GBase-BX SFP+ Module - Lifetime Warranty
Quicklinx: FJNHWS00 Mfr#: SFP-10GB-BX-U-20-ST
£257.53 ex VAT
£309.03 inc VAT
The SFP-10GB-BX-U-20-ST is a MSA Compliant upstream fiber SFP transceiver which pairs with StarTech.com's SFP-10GB-BX-D-20-ST. They are designed, programmed and tested to work with 10GBase-BX compatible MSA switches and routers. The SFP+ transceiver module supports a maximum distance of up to 20 km (12.4 mi) and delivers dependable 10 GbE connectivity over fiber cabling.
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP+ modules and direct-attach SFP+ Cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com MSA Uncoded SFP+ Module, 10GBASE-BX, 10 Gigabit Ethernet Bi-Directional (BiDi) Fiber Single Strand SFP+ Transceiver, LC 20km , Mini GBIC Transceiver SFP+ Module, Upstream BiDI - Lifetime Warranty (SFP-10GB-BX-U-20-ST) - SFP+ transceiver module - 10 GigE
SFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
10GBase-BX-U
Data Transfer Rate
10 Gbps
Optical Wave Length
1270 (TX) / 1330 (RX) nm
10 GigE
Max Transfer Distance
20 km
5.84 cm x 1.39 cm x 1.26 cm
24 g
Plug-in module
Wired
Cabling Type
10GBase-BX-U
10 GigE
Data Transfer Rate
10 Gbps
Optical Wave Length
20 km
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 10GBase-BX-U - LC single-mode female
MSA
5.84 cm
1.39 cm
1.26 cm
24 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
Stock Status: In stock
