StarTech.com Mountable 4 Port Rugged Industrial USB Hub
Quicklinx: 6B9LWS00 Mfr#: ST4200USBM
Type: USB Hub
Interface: USB 2.0
Speed: 480Mbps
Ports: 4
Form Factor: DIN rail mountable
  • Hi-Speed USB
More than 50 in stock
£48.66 ex VAT
£58.39 inc VAT
This sturdy, industrial grade USB hub can be wall mounted or installed onto a DIN rail for convenient access to its 4 female USB ports, providing a work area, server room, or industrial area with USB 2.0 connectivity. With support for Hi-Speed USB 2.0 data transfer rates of up to 480 Mbps, this 4 port USB hub is backwards compatible with USB 1.1 specifications and can be powered through the host USB bus, or self powered using a three wire terminal block connector (7-24V).
StarTech.com 4-Port Industrial USB 2.0 Hub with ESD Protection - Mountable - Multiport Hub (ST4200USBM) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB 2.0
DC 7 - 24 V
5.7 cm x 11.5 cm x 2.6 cm
Apple MacOS 8.6 or later, Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows Vista, Microsoft Windows 2003
P/N: MSDREADU2OTG
Hub - 4 ports
Enclosure Type
DIN rail mountable
Subtype
USB
Ports
4 x USB 2.0
Status Indicators
Port status, power
4 x USB 2.0 Type A , 1 x USB 2.0 Type B
DC 7 - 24 V
DIN-rail mounting kit
FCC, RoHS
5.7 cm
11.5 cm
2.6 cm
55 °C
P/N: MSDREADU2OTG
6B9L StarTech.com 15 ft USB 2.0 A to B Cable - M/M In Stock £4.33
6B9L StarTech.com 10 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.81
6B9L StarTech.com Mountable 4 Port Rugged Industrial USB Hub In Stock £48.66
6B9L StarTech.com Mountable Rugged Industrial 7 Port USB Hub In Stock £63.61
6B9L StarTech.com 6 ft USB 2.0 Certified A to B Cable - M/M In Stock £3.15
Type: USB Hub
Interface: USB 2.0
Speed: 480Mbps
Ports: 4
Price Range Ex VAT: 0 - 50
