StarTech.com Monitor Riser Stand for Corner Workstation - Height Adjust
Quicklinx: FF5FWS00 Mfr#: MONSTNDCORNR
Maximize your work space with this innovative monitor riser and stand, shaped to fit into the corner of a cubicle or corner workstation. You can raise your computer screen by placing it on this platform, for a more comfortable viewing, while saving desk space.
Set this sturdy height-adjustable monitor stand into the corner of your workstation, to support a monitor up to 32" in size and up to 33 lb. (15 kg) in weight. It sits neatly on your desk or table, leaving space for storage underneath. The monitor shelf even has a drawer to hold office supplies.
Create a workstation that works best for your needs. This monitor riser features legs extenders, giving you a choice of two heights for your monitor stand: 2.8" or 3.9" (7 cm or? 1? 0 cm).
The corner monitor stand makes it easy to create a clutter-free workspace. In the area under the desktop stand, between the legs, there is space to place a small laptop. A convenient drawer gives you a place to keep pens and other small office supplies.
The PC monitor stand is easy to assemble. The rubber feet on the bottom of the legs protect your work surface from scratches and ensures your monitor rests securely while you work.
StarTech.com Monitor Riser Stand for Corner Workstation - For up to 32" Monitors - Height Adjustable - Corner Monitor Stand (MONSTNDCORNR) - stand - for Monitor - black
Stand
27.1 cm x 55 cm
Adjustable Height
7-10 cm
Adjustments
2 kg
Recommended Use
Monitor
Recommended Display Size
32"
Max Load Weight
15 kg
Material
Plastic, MDF
Package Content
4 x rubber feet, 4 x stand risers, 4 x riser extenders
5-year warranty
27.1 cm
55 cm
Adjustable Height
7-10 cm
2 kg
Material
Plastic, MDF
Package Content
AV Furniture
Stand
Recommended Use
Monitor
Drawers Qty
1
32"
Adjustments
Max Load Weight
15 kg
Dimensions & Weight Details
27.8 cm x 55.5 cm x 6.3 cm / 2 kg
Limited warranty - 5 years
FF5F StarTech.com Portable Laptop Stand In Stock £18.40
FF5F StarTech.com Monitor Riser Stand In Stock £46.64
FF5F StarTech.com Monitor Riser Stand for up to 34" Monitors In Stock £47.85
FF5F StarTech.com Laptop Stand - 2-in-1 Riser/Vertical Stand In Stock £25.62
FF5F StarTech.com Laptop Stand for Desk In Stock £72.84
