StarTech.com Monitor Desk Mount - Steel
Quicklinx: CRY4WS00 Mfr#: ARMPIVOTV2
Stock Status: Clearance
Hurry, only 1 left in stock!
£32.85 ex VAT
£39.42 inc VAT
Express delivery Delivered on Wednesday
Create an ergonomic work area and save space by mounting your monitor above your desk, and re-position easily. Save valuable desk space and position your monitor in a more comfortable viewing position. Constructed of high-grade steel, this monitor desk mount for up to 32" monitors makes it easy to suspend your display above your desk or other work surface.
Clear up your desk surface while creating an ergonomic workspace. This simple yet rugged monitor mount supports displays 13" to 32" (330 to 813 mm) in size and 17.6 lb. (8 kg) in weight. Easily rotate, tilt and swivel, to adjust your screen position and find the perfect viewing angle. You can also adjust the height of your monitor along the vertical pole to a maximum height of 17.4" (443 mm) to your desired position, to reduce neck and eye strain.
The heavy-duty steel mount is built for long-lasting performance. The surface finish features a powder coating to help resist scratches.
The monitor desk mount makes it easy to mount a VESA mount compatible display above your desk, table or other surface, using the included C-clamp or grommet mount. A detachable VESA panel enables simple attachment of your monitor, then you just slide your monitor onto the mount. To help keep your work area free of clutter, the monitor mount also features cable clips that keep your cables neatly out of sight.
StarTech.com Monitor Desk Mount - Steel - For VESA Mount Monitors up to 32" - desk mount
Desk mount - C-clamp, grommet
11.4 cm x 54.8 cm x 14.8 cm
Tilt
-45° to 45°
Pan
180°
Rotation
360°
Adjustments
Height, swivel
Recommended Use
Monitor
Recommended Display Size
13"-32"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Plastic, steel
Package Content
4 x M4x12 screws, hex key (4mm), 4 x M5x12 screws, spacers, 5 x rubber pads, grommet collar, hex key (6mm), thumbscrew, 4 x M4x16 screws, 3 x pole screws
5-year warranty
11.4 cm
54.8 cm
14.8 cm
Material
Plastic, steel
Package Content
AV Furniture
Desk mount
Mounting Components
Desk clamp mount, pole clamp, pole, grommet plate, washers, cable management clip
Recommended Use
Monitor
Placing / Mounting
C-clamp, grommet
13"-32"
Tilt
-45° to 45°
Pan
180°
Rotation
360°
Adjustments
Height, swivel
Max Load Weight
8 kg
Limited warranty - 5 years
StarTech.com Monitor Desk Mount - Steel Bundle deal on StarTech.com Monitor Desk Mount - Steel
£132.02
Price Range Ex VAT: 0 - 50
