Your basket is empty
StarTech.com Mini VGA Video and Audio Extender over Cat5
Quicklinx: 76Q8WS00 Mfr#: ST121UTPMINI
Extend a VGA signal with audio to a remote display over Cat 5 or better cabling with this small form-factor device. The ST121UTPMINI Mini VGA Video and Audio Extender over Cat 5 provides a complete high resolution point-to-point digital signage solution, comprised of one local transmitter and one remote receiver.
Simply connect the local (transmitter) unit to the VGA video and audio source, and the remote unit to a VGA display up to 90 meters (275 feet) away. To start extending the VGA and audio signal, create a point-to-point connection by using Cat 5 / Cat 6 UTP cable.
The Cat 5 VGA extender provides a cost-effective way to situate your display as needed, eliminating standard distance limitations for a more effective digital signage configuration. This small form factor extender is compact enough to be tucked away behind the display even when space is limited.
StarTech.com Mini VGA Video and Audio Extender over Cat5 - video/audio extender
Video/audio extender
External
Max Transfer Distance
90 m
DC 5 V
2 years warranty
External
Blue
Wired
90 m
Status Indicators
Port status
USB powered
1 x VGA - HD-15 , 1 x audio - mini jack
External power adapter
DC 5 V
76Q8 StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.73
76Q8 StarTech.com 6 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F In Stock £5.73
76Q8 StarTech.com 15 ft Coax VGA Monitor Extension Cable - HD15 M/F In Stock £9.91
76Q8 StarTech.com 25 ft Cat5e Blue Snagless RJ45 UTP Cat 5e Patch Cable - 25ft Patch Cord In Stock £4.17
76Q8 StarTech.com DC Power Adapter - 5V, 3A In Stock £10.69
