Product
StarTech.com Mini USB Bluetooth 2.1 Adapter Class 1 EDR Wireless Network Adapter
Quicklinx: 7ZMQWS00 Mfr#: USBBT1EDR2
£11.19 ex VAT
£13.42 inc VAT
Add Bluetooth 2.0 with EDR capabilities to a computer, through USB. The USBBT1EDR2 USB to Class 1 Bluetooth Adapter with EDR is a micro-sized adapter that adds Bluetooth capabilities to a computer through an available USB port. This makes it possible to connect to devices wirelessly, at ranges up to 100m (328ft), with minimal power consumption. The USB-Bluetooth Adapter supports the Bluetooth v2.1 specification, along with Enhanced Data Rate (EDR), for transfer rates up to 3 Mbps. The adapter uses a small form factor design that makes it conveniently portable and unobtrusive, when connected to a computer.
StarTech.com Mini USB Bluetooth 2.1 Adapter - Class 1 EDR Wireless Network Adapter - network adapter
Network adapter
External
Interface (Bus) Type
USB
1 cm x 2 cm x 0.6 cm
2 g
Bluetooth 2.1 EDR
Bluetooth Class
Class 1
Data Transfer Rate
3 Mbps
Frequency Band
2.4 GHz
Bluetooth 2.1
Apple MacOS X, Microsoft Windows 2000/XP/Vista/7, Windows 10 (32/64 bits)
2 years warranty
Network adapter
External
USB
Wireless
Bluetooth 2.1 EDR
Bluetooth Class
Class 1
Data Transfer Rate
3 Mbps
Line Coding Format
DQPSK, GFSK, 8 DPSK
Frequency Band
2.4 GHz
Max Range Open Space
100 m
Status Indicators
Power, standby
USB powered
Bluetooth 2.1
Aerial
Antenna
Internal
1 x USB - 4 pin USB Type A
FCC, RoHS
1 cm
2 cm
0.6 cm
2 g
-10 °C
50 °C
Price Range Ex VAT: 0 - 50
