StarTech.com Mini Thunderbolt 3 Dock - MacBook Pro & Windows - Dual 4K 60Hz DP - Bus Powered
Quicklinx: DHP1WS00 Mfr#: TB3DKM2DP
Device Type: Laptop, Macbook
Type: Docking Stations
Colour: Black
29 in stock
£89.11 ex VAT
£106.93 inc VAT
Create a dual-monitor bus powered workstation, with two 4K DisplayPort displays, one USB 3.0 and Gigabit Ethernet port, and flexible desktop setup with extended length cable. This Thunderbolt 3 docking station packs big performance into a compact mini dock, delivering 4K UHD video performance to two DisplayPort monitors simultaneously. Compatible with macOS and Windows, it's the ideal accessory for your MacBook Pro, Dell XPS or other Thunderbolt 3 laptop.
Great for editing 4K video or other Ultra HD tasks, the Thunderbolt 3 dock, with 40Gbps of throughput, supports 4K resolution at 60Hz on two DisplayPort monitors, through a single Thunderbolt 3 port. Run resource-demanding applications on two independent displays (at up to 4096 x 2160p resolutions) without draining system resources. You can also connect a single 5K 60Hz display to your laptop.
To enhance your productivity, the Gigabit Ethernet port ensures reliable wired network access. Plus, a USB 3.0 Type-A port, with ample space around it, lets you connect a USB device, like a flash drive, for easy file access.
This mini Thunderbolt 3 dock offers a versatile solution for permanent and shared office workspaces, with a compact design that's portable enough to take with your laptop wherever you go. It's bus-powered, with no external power required. For flexible setup, the attached USB-C cable has an extended length of 20 cm.
StarTech.com Mini Dual 4K Monitor Thunderbolt 3 Dock with DisplayPort - Mac & Windows (TB3DKM2DP) - docking station - 2 x DP
Docking station
Docking Interface
Thunderbolt 3
Video Interfaces
2 x DP
6 cm x 12 cm x 1.88 cm
145.8 g
Gigabit Ethernet
3-year warranty
Docking station
6 cm
12 cm
1.88 cm
145.8 g
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0, USB 3.1
1 x Thunderbolt 3 - 24 pin USB-C , 2 x display / video - DisplayPort output - 20 pin DisplayPort , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x Thunderbolt 3 / USB-C cable - integrated - 20 cm
FCC, RoHS, WEEE, RCM, UASP (USB Attached SCSI Protocol)
Microsoft Windows 7 / 8 / 8.1 / 10, Apple MacOS X 10.12 - 10.14
Limited warranty - 3 years
Shipping Weight
268.2 g
5 °C
35 °C
StarTech.com Mini Thunderbolt 3 Dock - MacBook Pro & Windows - Dual 4K 60Hz DP - Bus Powered Bundle deal on StarTech.com Mini Thunderbolt 3 Dock - MacBook Pro & Windows - Dual 4K 60Hz DP - Bus Powered
£188.28
DHP1 StarTech.com DisplayPort to DVI Active Adapter In Stock £21.76
DHP1 StarTech.com Mini Thunderbolt 3 Dock - MacBook Pro & Windows - Dual 4K 60Hz DP - Bus Powered In Stock £89.11
DHP1 StarTech.com Mini Thunderbolt 3 Dock - Dual 4K HDMI In Stock £117.02
Device Type: Laptop
Device Type: Macbook
Colour: Black
Price Range Ex VAT: 50 - 100
