StarTech.com Mini Thunderbolt 3 Dock - MacBook Pro & Windows - Dual 4K 60Hz DP - Bus Powered
Quicklinx: DHP1WS00 Mfr#: TB3DKM2DP
Create a dual-monitor bus powered workstation, with two 4K DisplayPort displays, one USB 3.0 and Gigabit Ethernet port, and flexible desktop setup with extended length cable. This Thunderbolt 3 docking station packs big performance into a compact mini dock, delivering 4K UHD video performance to two DisplayPort monitors simultaneously. Compatible with macOS and Windows, it's the ideal accessory for your MacBook Pro, Dell XPS or other Thunderbolt 3 laptop.
Great for editing 4K video or other Ultra HD tasks, the Thunderbolt 3 dock, with 40Gbps of throughput, supports 4K resolution at 60Hz on two DisplayPort monitors, through a single Thunderbolt 3 port. Run resource-demanding applications on two independent displays (at up to 4096 x 2160p resolutions) without draining system resources. You can also connect a single 5K 60Hz display to your laptop.
To enhance your productivity, the Gigabit Ethernet port ensures reliable wired network access. Plus, a USB 3.0 Type-A port, with ample space around it, lets you connect a USB device, like a flash drive, for easy file access.
This mini Thunderbolt 3 dock offers a versatile solution for permanent and shared office workspaces, with a compact design that's portable enough to take with your laptop wherever you go. It's bus-powered, with no external power required. For flexible setup, the attached USB-C cable has an extended length of 20 cm.
  • Create a Dual-4K 60Hz Workstation
    Great for editing 4K video or other Ultra HD tasks, this portable dual DisplayPort docking station supports 40Gbps of throughput and 4K resolution at 60Hz on two DisplayPort monitors, through a single Thunderbolt 3 port. Connect your laptop to:
  • Easy Installation & Deployment
    Simply connect the?TB3 dock?to your laptop with included TB3 cable and start working immediately. No?time-consuming driver installations are required.
  • The Ports You Need Most
    To enhance your productivity, the Gigabit Ethernet port (with PXE Boot and Wake-on-LAN support) ensures reliable wired network access. A USB 3.0 Type-A port, with ample space around it, lets you connect a USB device, like a flash drive, for easy file access.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
StarTech.com Mini Thunderbolt 3 Dock - MacBook Pro/Windows, Dual 4K 60Hz DP - Discontinued, Limited Stock, & Replaced by TB3DKM2DPL (TB3DKM2DP) - docking station - Thunderbolt 3 - 2 x DP - 1GbE
Docking station
Docking Interface
Thunderbolt 3
Video Interfaces
2 x DP
6 cm x 12 cm x 1.88 cm
145.8 g
Gigabit Ethernet
3-year warranty
Docking station
6 cm
12 cm
1.88 cm
145.8 g
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0, USB 3.1
1 x Thunderbolt 3 - 24 pin USB-C , 2 x display / video - DisplayPort output - 20 pin DisplayPort , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x Thunderbolt 3 / USB-C cable - integrated - 20 cm
FCC, RoHS, WEEE, RCM, UASP (USB Attached SCSI Protocol)
Apple macOS 10.12 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
Shipping Weight
268.2 g
5 °C
35 °C
DHP1 StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £15.80
DHP1 StarTech.com DisplayPort to DVI Active Adapter In Stock £22.91
DHP1 StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 In Stock £65.80
DHP1 StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter In Stock £21.47
DHP1 StarTech.com DisplayPort to HDMI - 4K 60Hz In Stock £23.58
DHP1 StarTech.com Thunderbolt 3 Mini Dock - Dual Monitor HDMI 4K 60Hz - 2x USB-A (USB 3.2 / 2.0) In Stock £114.04
DHP1 StarTech.com Thunderbolt 3 Mini Dock - Dual Monitor DP 4K 60Hz - 1x USB/GbE In Stock £88.21
