StarTech.com Mini Thunderbolt 3 Dock - Dual 4K HDMI
Quicklinx: DXDPWS00 Mfr#: TB3DKM2HD
Device Type: Laptop, Macbook
Type: Docking Stations
Colour: Black
Stock Status: In Stock, Used Stock
More than 50 in stock
£117.02 ex VAT
£140.42 inc VAT
This Thunderbolt 3 docking station packs big performance into a cost-effective, compact mini dock, delivering essential connections for productivity. The bus-powered Thunderbolt 3 dock lets you connect to dual 4K HDMI displays, Gigabit Ethernet and two USB (Type-A) ports. Compatible with macOS and Windows, it's the ideal accessory for your MacBook Pro, Dell XPS or other Thunderbolt 3 laptop.
Great for editing 4K video or other Ultra HD tasks, this portable Thunderbolt 3 to HDMI dock supports 40Gbps of throughput and 4K resolution at 60Hz on dual HDMI monitors, through a single Thunderbolt 3 port. Run resource-demanding applications on two independent displays without draining system resources.
Connect your laptop to 2x 4K HDMI displays (up to 4096 x 2160p @ 60Hz).
To enhance your productivity, the Gigabit Ethernet port (with PXE Boot and Wake-on-LAN support) ensures reliable wired network access. A USB 3.0 Type-A port, with ample space around it, lets you connect a USB device, such as a flash drive, for easy file access. Connect another USB device using the USB 2.0 Type-A port.
This mini dual 4K docking station offers a versatile solution for permanent and shared office workspaces. It's bus-powered, with no external power required. For flexible setup, the attached USB-C cable has an extended length of (7.9 in./ 20 cm).
StarTech.com Mini Dual 4K Monitor Thunderbolt 3 Dock with HDMI - Mac & Windows (TB3DKM2HD) - docking station - 2 x HDMI
Docking station
Docking Interface
USB-C 3.1 / Thunderbolt 3
Video Interfaces
2 x HDMI
6 cm x 12 cm x 1.88 cm
145.8 g
Black & grey
Gigabit Ethernet
3-year warranty
Docking station
6 cm
12 cm
1.88 cm
145.8 g
Enclosure Colour
Black & grey
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0, USB 3.1
1 x USB-C 3.1 / Thunderbolt 3 - 24 pin USB-C , 2 x display / video - HDMI - 19 pin HDMI Type A , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x USB 2.0 - 4 pin mini-USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x Thunderbolt 3 / USB-C cable - integrated - 20 cm
USB powered, dual display support, Preboot Execution Environment (PXE) support, full duplex support, 4K Ultra HD, auto MDIX support
FCC, RoHS, UASP (USB Attached SCSI Protocol)
Microsoft Windows 7 / 8 / 8.1 / 10, Apple MacOS X 10.12 - 10.14
Limited warranty - 3 years
Shipping Weight
268.2 g
5 °C
35 °C
StarTech.com Mini Thunderbolt 3 Dock - Dual 4K HDMI Bundle deal on StarTech.com Mini Thunderbolt 3 Dock - Dual 4K HDMI
£216.19
DXDP StarTech.com Mini Thunderbolt 3 Dock - MacBook Pro & Windows - Dual 4K 60Hz DP - Bus Powered In Stock £89.11
DXDP StarTech.com Mini Thunderbolt 3 Dock - Dual 4K HDMI In Stock £117.02
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: DXDP 040790
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not present or functional  £16.41
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Device Type: Laptop
Device Type: Macbook
Colour: Black
Stock Status: Used Stock
Price Range Ex VAT: 100 - 150
