Add high speed Wireless-N connectivity through a Mini PCI Express slot. The MPEX300WN2X2 Mini PCI Express Wireless N Card lets you add high-speed 802.11n network connectivity to your laptop or small form factor system, with support for data transfer rates up to 300Mbps.
For efficient wireless communication, the card uses a 2T2R (2 Transmitter, 2 Receiver) Multiple Input/Multiple Output design over the 2.4GHz frequency. MIMO antenna configurations employ multiple signal paths for greater bandwidth, fewer lost packets and greater reception, even under conditions of interference.
The 300Mbps wireless N adapter offers the necessary speeds for demanding network applications such as streaming video, VoIP and network backups, while also offering backward compatibility with 802.11b/g networks (11/54Mbps) to connect to older WiFi routers as needed.
Using a half-height mini PCI express (Half Mini Card) form factor, this adapter is designed for use in the latest notebooks, small form factor computers (e.g. Mini-ITX), or custom embedded solutions where standard PCIe cards would not fit.
- StarTech.com Mini PCI Express Wireless N Card - 300Mbps 802.11b/g/n 2T2R - network adapter - PCIe Mini Card
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express Mini Card
- 2.65 cm x 0.3 cm x 2.98 cm
- 4 g
- Data Link Protocol
- 802.11b/g/n
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Vista / XP / 7, Linux Kernel 2.6.35, Windows 8, Microsoft Windows Server 2012, Windows 10 (32/64 bits)
- 2-year warranty
- Network adapter
- Form Factor
- Plug-in card
- Connectivity Technology
- Wireless
- 300 Mbps
- Frequency Band
- 2.4 GHz
- 2T2R MIMO technology
- FCC, RoHS
- OS Required
- 2.65 cm
- 0.3 cm
- 2.98 cm
- 4 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90%
