Connect a Mini HDMI equipped Digital Camera or Tablet to your VGA Display, or Projector. The MNHD2VGAE2 HDMI Mini HDMI to VGA adapter/converter actively converts an HDMI Mini source video signal from your digital camera or tablet PC, onto a VGA projector or display. The adapter supports full 1080p resolutions, making it a convenient choice for applications requiring high-definition capability. The Mini HDMI to VGA adapter is intended for displaying user generated content such as presentations, documents, and work sheets onto a VGA projector or monitor.
The HDMI Mini/VGA adapter features a compact design, with no need for an external power source, which ensures a compact and portable solution that is easy to carry as an accessory.
- StarTech.com Mini HDMI® to VGA Adapter Converter for Digital Still Camera / Video Camera - 1920x1080 - Mini HDMI Male to VGA HD15 Female (MNHD2VGAE2) - video converter - black
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x HDMI input - 19 pin mini HDMI Type C , 1 x VGA output - 15 pin HD D-Sub (HD-15)
- 4 cm x 17 cm x 1.5 cm
- Enclosure Colour
- Black
- 3-year warranty
- Video converter
- Max Resolution
- 1920 x 1200 at 60 Hz
- 1 x HDMI input - 19 pin mini HDMI Type C - male , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female
- FCC, RoHS
- 4 cm
- 17 cm
- 1.5 cm
- Enclosure Colour
- Black
- Limited warranty - 3 years
- 0 °C
- 60 °C
- 40 - 85% (non-condensing)
