StarTech.com Mini DVI to VGA Video Cable Adapter for Macbooks and iMacs
Quicklinx: 6BCNWS00 Mfr#: MDVIVGAMF
Connect an Apple mini DVI-equipped computer to a VGA monitor. This MINI DVI TO VGA Female Video Adapter Cable allows the video signal from a mini DVI equipped device to be output to any VGA monitor - a cost-effective solution that lets you add an external display to an Apple MacBook or iMac computer, creating a simple dual monitor setup.
StarTech.com Mini DVI to VGA Video Cable Adapter for Macbooks and iMacs - Video adapter - mini-DVI (M) to HD-15 (VGA) (F) - 7.9 in - white - MDVIVGAMF - video adapter - 20 cm
Video adapter
Length
20 cm
Connector
Mini-DVI - male
Connector (Second End)
HD-15 (VGA) - female
White
Video adapter
Length
20 cm
White
Connector
Apple mini-DVI - male
15 pin HD D-Sub (HD-15) - female
