StarTech.com mini DisplayPort to VGA DVI or HDMI Adapter
Quicklinx: C7C3WS00 Mfr#: MDPVGDVHD4K
Hurry, only 1 left in stock!
£27.07 ex VAT
£32.48 inc VAT
Keep this compact converter with your laptop while you're traveling, to connect to virtually any monitor, television or projector. This 3-in-1 travel adapter offers a portable solution for connecting your Mini DisplayPort computer to a VGA, DVI or HDMI display.
The adapter is VESA certified, to ensure compatibility with your mDP computer.
This travel adapter has been constructed with a sturdy aluminum housing and features a pure white Mini DisplayPort cable built in. While the adapter looks great and works well with any mDP device, it's designed to seamlessly match your MacBook Air or MacBook Pro.
Instead of filling your laptop bag with different converters for different displays, this 3-in-1 adapter gives you all the video outputs you'll need. With VGA, DVI and HDMI outputs, this adapter lets you connect from your laptop's Mini DisplayPort port to any boardroom or classroom display, without the inconvenience of carrying a separate adapter for each display type.
With support for multiple video outputs and a lightweight, small-footprint design, this adapter is the ideal plug-and-play solution for travel or BYOD (Bring Your Own Device) applications around the office.
The adapter features a built-in magnetic fastener, for cable management. The magnet helps guide the breakout cable into place for quick and secure storage while traveling, ensuring the adapter is neatly stored in your travel bag.
The HDMI output on this adapter supports Ultra HD 4K resolutions, providing four times the picture quality of high-definition 1080p. The HDMI output is also backward compatible with lower resolutions, such as 1080p and 720p, so the adapter is also perfect for your legacy video equipment. The VGA and DVI outputs also support a high-definition maximum resolution up to 1920 x 1200, so you can still enjoy excellent video quality.
The travel adapter is compatible with mDP Intel Thunderbolt devices that are capable of outputting a DisplayPort signal.
StarTech.com Aluminum Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA, DVI or HDMI - mDP Adapter - 4K (MDPVGDVHD4K) - video converter
Video converter
Max Resolution
1920 x 1200
Max Resolution Details
DVI: 1920 x 1200 / HDMI: 3840 x 2160 / VGA: 1920 x 1200
1 x DisplayPort input - Mini DisplayPort , 1 x HDMI output - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x DVI-D output - 24+1 pin digital DVI
4.7 cm x 9 cm x 1.4 cm
3-year warranty
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - Mini DisplayPort - male , 1 x HDMI output - 19 pin HDMI Type A - female , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female , 1 x DVI-D output - 24+1 pin digital DVI - female
HD/4k Ready, 7.1 channel surround sound ready
DisplayPort 1.2
4.7 cm
9 cm
1.4 cm
Limited warranty - 3 years
70 °C
40 - 50%
C7C3 StarTech.com Mini DisplayPort to DisplayPort / DVI / HDMI Adapter – 3-in-1 mDP Converter In Stock £19.49
C7C3 StarTech.com Mini DisplayPort to HDMI Video Adapter Converter - White In Stock £10.37
C7C3 StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter In Stock £25.02
C7C3 StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black In Stock £33.81
C7C3 StarTech.com Travel A/V Adapter: 3-in-1 Mini DisplayPort to VGA DVI or HDMI In Stock £25.52
C7C3 StarTech.com mDP to HDMI or VGA Converter In Stock £18.48
C7C3 StarTech.com mDP to HDMI or VGA Converter In Stock £13.32
C7C3 StarTech.com DP to HDMI or VGA Converter In Stock £15.99
C7C3 StarTech.com mini DisplayPort to VGA DVI or HDMI Adapter In Stock £27.07
C7C3 StarTech.com USB-C Multiport Video Adapter 4-in-1 - 95W Power Delivery - Space Gray - 4K 60Hz In Stock £67.25
Stock Status: In stock
