StarTech.com Mini DisplayPort to HDMI Adapter with USB Audio
Quicklinx: 76MQWS00 Mfr#: MDP2HDMIUSBA
Type: DisplayPort
Length: 0.6m
£68.26 ex VAT
£81.91 inc VAT
Connect an HDMI display to a Mini-DisplayPort source with audio.
The MDP2HDMIUSBA Mini DisplayPort with USB Audio to HDMI Adapter offers a cost-effective HDMI with audio to Mini DisplayPort link, letting you connect an HDMI-capable HDTV to a device with a Mini DisplayPort output, while saving the expense of upgrading the TV for compatibility. Simply plug in the USB and Mini DisplayPort connectors to a PC or Mac and the HDMI connector to an HDMI television/monitor. 2-channel analog audio will pass through to the HDMI connection, delivering sound to the display side, with the convenience of one HDMI cable. MDP2HDMIUSBA is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port. Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
StarTech.com Mini DisplayPort to HDMI Adapter with USB Audio - video converter - black
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - Mini DisplayPort , 1 x HDMI output - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A
16.2 cm x 5.6 cm x 1 cm
Enclosure Colour
3-year warranty
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - Mini DisplayPort - male , 1 x HDMI output - 19 pin HDMI Type A - female , 1 x USB - 4 pin USB Type A - male
LED indicator, USB powered, USB audio interface, HDCP
1 x video / USB cable - 60 cm
RoHS
16.2 cm
5.6 cm
1 cm
90 g
Enclosure Colour
Limited warranty - 3 years
5 °C
35 °C
0 - 80%
76MQ StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.00
76MQ StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £15.85
76MQ StarTech.com Mini DisplayPort to DVI Video Adapter Converter In Stock £10.46
76MQ StarTech.com Mini DisplayPort to VGA Video Adapter Converter In Stock £19.01
76MQ StarTech.com Mini DisplayPort to HDMI Video Adapter Converter In Stock £9.84
76MQ StarTech.com Mini DisplayPort to HDMI Adapter with USB Audio In Stock £68.26
Type: DisplayPort
Length: 0.6m
Price Range Ex VAT: 50 - 100
