Your basket is empty
StarTech.com Mini DisplayPort to HDMI Active Video and Audio Adapter Converter - White
Quicklinx: 8KRDWS00 Mfr#: MDP2HDSW
Connect an HDMI Display to a Single Mode Mini DisplayPort Video Source. The MDP2HDSW White Mini DisplayPort to HDMI Adapter features audio pass-through support, which enables you to connect both the audio and video from Mini DisplayPort-equipped desktop or laptop computer to an HDMI monitor, projector, or display.
With a sleek design and uniform look, this white Mini DisplayPort to HDMI adapter is ideal for Mac users.
Unlike a passive adapter, the MDP2HDS actively converts single-mode and dual mode Mini DisplayPort output, which is ideal for graphics cards that do not output dual mode/multi-mode (DP++) signals, such as ATI Eyefinity cards.
This active Mini DP to HDMI adapter is compatible with Intel Thunderbolt output, when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
StarTech.com Mini DisplayPort to HDMI Active Video and Audio Adapter Converter - video converter - white
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - Mini DisplayPort , 1 x HDMI output - 19 pin HDMI Type A
4 cm x 21.1 cm x 1.5 cm
Enclosure Colour
White
2 years warranty
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - Mini DisplayPort - male , 1 x HDMI output - 19 pin HDMI Type A - female
HDCP
FCC, RoHS
4 cm
21.1 cm
1.5 cm
29.8 g
Enclosure Colour
White
60 °C
40 - 85%
