Product
Brand
StarTech.com Mini DisplayPort to HDMI Active Video and Audio Adapter Converter - 1920x1200
Quicklinx: 8G41WS00 Mfr#: MDP2HDS
Connect an HDMI Display to a Mini DisplayPort Video Source. The MDP2HDS Adapter converts Mini DisplayPort to HDMI with audio pass-through support, enabling you to connect a desktop or laptop computer that is equipped with Mini DisplayPort A/V output to an HDMI monitor, projector, or display.
Unlike a passive adapter, the MDP2HDS actively converts single mode and dual mode DisplayPort output, which is ideal for graphics cards that do not output dual mode/multi-mode (DP++) signals, such as ATI Eyefinity cards.
The Mini DP to HDMI adapter is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
StarTech.com Mini DisplayPort to HDMI Active Video and Audio Adapter Converter - video converter - black
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - Mini DisplayPort , 1 x HDMI output - 19 pin HDMI Type A
4 cm x 21.1 cm x 1.5 cm
Enclosure Colour
2 years warranty
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - Mini DisplayPort - male , 1 x HDMI output - 19 pin HDMI Type A - female
HDCP
FCC, RoHS
4 cm
21.1 cm
1.5 cm
30 g
Enclosure Colour
60 °C
40 - 85%
