Product
StarTech.com Mini DisplayPort to HDMI 4K Audio / Video Converter – mDP 1.2 to HDMI Active Adapter
Quicklinx: 9NY5WS00 Mfr#: MDP2HD4KSW
25 in stock
£16.47 ex VAT
£19.76 inc VAT
Connect an HDMI Display to a Single Mode Mini DisplayPort video source. The MDP2HD4KSW Mini DisplayPort to HDMI enables you to connect a mDP-equipped computer, such as the MacBook Pro and MacBook Air, to an HDMI display.This adapter is compatible with Mini DisplayPort 1.2 & HDMI 4K @ 30 Hz and as a result can support video resolutions up to Ultra HD (4K) as well as the accompanying digital audio up to 7.1 channel surround sound.
With support for Ultra HD (4K) the mDP to HDMI adapter ensures you can convert Mini DisplayPort to HDMI while maintaining an astonishing picture quality four times the resolution of high-definition 1080p. The adapter is also backward compatible with previous DisplayPort revisions 1.0/1.1 with support for resolutions up to 1080p.
For a hassle-free setup the Mini DisplayPort to HDMI adapter allows for plug-and-play installation without any additional software or drivers.Plus, with a small footprint and lightweight design, the adapter.
To ensure compatibility with any Mini DisplayPort output the mDP adapter offers an active conversion. Active video conversion is required to maintain 4K resolutions when converting Mini DisplayPort to HDMI. An active mDP adapter is also ideal for outputting 1080p resolutions by ensuring compatibility with graphics cards that are not capable of outputting multi-mode DP++ signals (e.g. ATI Eyefinity).
To support your Mac the HDMI converter is compatible with Intel Thunderbolt devices that output a DisplayPort video signal.
With a sleek uniform white design the MDP2HD4KSW looks great next to your Mac.
StarTech.com Mini DisplayPort to HDMI 4K Audio/Video Adapter Converter - video converter - white
Video converter
Max Resolution
4096 x 2160
1 x DisplayPort input - Mini DisplayPort , 1 x HDMI output - 19 pin HDMI Type A
Enclosure Colour
White
2 years warranty
Apple MacBook Air; MacBook Pro
Video converter
Max Resolution
4096 x 2160
1 x DisplayPort input - Mini DisplayPort - male , 1 x HDMI output - 19 pin HDMI Type A - female
Active cable (signal regeneration), HDCP
1 x video adapter - 15 cm
FCC, RoHS
55 g
Enclosure Colour
White
70 °C
10 - 85%
Apple MacBook Air , Apple MacBook Pro
Price Range Ex VAT: 0 - 50
