Brand
StarTech.com Mini DisplayPort to DVI Video Adapter Converter - White
Quicklinx: 81T5WS00 Mfr#: MDP2DVIW
27 in stock
£10.54 ex VAT
£12.64 inc VAT
Connect a DVI display to a Mini-DisplayPort-equipped PC or Mac computer. The MDP2DVIW passive Mini DisplayPort to DVI Adapter (White) offers an easy-to-use DVI/Mini-DisplayPort link that enables you to connect a DVI computer monitor to a device with a Mini-DisplayPort output (such as a laptop video out port) or video card.
The adapter supports high resolution output up to 1920x1200, offering a cost-effective solution for mirroring or extending a computer desktop onto a second display. Plus, because the adapter functions passively, it can be used with a DVI to HDMI adapter, to connect an HDMI-equipped monitor to a Mini DisplayPort output.
This versatile Mini DisplayPort to DVI adapter requires a multimode DisplayPort port (DisplayPort ++) connection to function, and is compatible with Intel Thunderbolt output when directly connected to a supporting DisplayPort over Thunderbolt I/O port.
StarTech.com Mini DisplayPort to DVI Adapter - White - 1920 x 1200 - Mini DP to DVI Converter for Your Mac or Windows Computer (MDP2DVIW) - DVI adapter - 17 cm
DVI adapter
Length
17 cm
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-I - female
FCC, RoHS
White
3-year warranty
DVI adapter
Length
17 cm
White
Connector
24+5 pin combined DVI - female
FCC, RoHS
3-year warranty
81T5 StarTech.com 15 ft DVI-D Dual Link Cable - M/M In Stock £15.66
81T5 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £8.48
81T5 StarTech.com Mini DisplayPort to DVI Video Adapter Converter In Stock £10.54
81T5 StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M In Stock £23.28
81T5 StarTech.com Mini DisplayPort to DVI Video Adapter Converter - White In Stock £10.54
81T5 StarTech.com Mini DisplayPort to DVI Video Adapter Converter - Black Mini DP to DVI - 1920x1200 In Stock £10.54
81T5 StarTech.com 6 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black In Stock £14.78
81T5 StarTech.com 6 ft Mini DisplayPort to DVI Active Adapter Converter Cable - 2560x1600 – Black In Stock £24.38
81T5 StarTech.com 3 ft Mini DisplayPort to DVI Active Adapter Converter Cable – 2560x1600 Black In Stock £21.29
Stock Status: In stock
