Connect a DVI display to a Mini-DisplayPort-equipped PC or Mac computer. The MDP2DVIW passive Mini DisplayPort to DVI Adapter (White) offers an easy-to-use DVI/Mini-DisplayPort link that enables you to connect a DVI computer monitor to a device with a Mini-DisplayPort output (such as a laptop video out port) or video card.
The adapter supports high resolution output up to 1920x1200, offering a cost-effective solution for mirroring or extending a computer desktop onto a second display. Plus, because the adapter functions passively, it can be used with a DVI to HDMI adapter, to connect an HDMI-equipped monitor to a Mini DisplayPort output.
This versatile Mini DisplayPort to DVI adapter requires a multimode DisplayPort port (DisplayPort ++) connection to function, and is compatible with Intel Thunderbolt output when directly connected to a supporting DisplayPort over Thunderbolt I/O port.
- StarTech.com Mini DisplayPort to DVI Adapter - White - 1920 x 1200 - Mini DP to DVI Converter for Your Mac or Windows Computer (MDP2DVIW) - DVI adapter - 17 cm
- DVI adapter
- Length
- 17 cm
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- DVI-I - female
- FCC, RoHS
- White
- 3-year warranty
- DVI adapter
- Length
- 17 cm
- White
- Connector
- 24+5 pin combined DVI - female
- FCC, RoHS
- 3-year warranty
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £8.66 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter | In Stock | £10.74 |
StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M | In Stock | £26.12 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter - White | In Stock | £10.89 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter - Black Mini DP to DVI - 1920x1200 | In Stock | £10.96 |
StarTech.com 6 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black | In Stock | £14.81 |
StarTech.com 6 ft Mini DisplayPort to DVI Active Adapter Converter Cable - 2560x1600 – Black | In Stock | £23.82 |
StarTech.com 3 ft Mini DisplayPort to DVI Active Adapter Converter Cable – 2560x1600 Black | In Stock | £21.72 |
