Product
StarTech.com Mini DisplayPort to DVI Active Adapter
Quicklinx: 7NZMWS00 Mfr#: MDP2DVIS
Stock Status: Clearance
Hurry, only 1 left in stock!
£21.76 ex VAT
£26.11 inc VAT
The MDP2DVIS Mini DisplayPort to DVI Active Adapter (single-link) lets you connect your Mini-DisplayPort video source to a DVI-D display, including televisions and Apple Cinema Display HD, eliminating the expense of having to upgrade to a DisplayPort capable monitor.
Unlike passive video adapters, this Mini DisplayPort to DVI adapter offers an active conversion for use with any Mini DisplayPort output - ideal for graphics cards that are not capable of outputting multi-mode DP++ signals (e.g. ATI Eyefinity).
Supporting resolutions up to 1920x1200, this compact device provides a simple solution for adapting PC or Mac Mini-DisplayPort output for DVI monitors, televisions or projectors.
The Mini DP to DVI adapter is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port.
StarTech.com Mini DisplayPort to DVI Active Adapter - DVI adapter - 20 cm
DVI adapter - dual link
HDCP compliant
Length
20 cm
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-D - female
FCC, RoHS
2 years warranty
DVI adapter
TMDS Links
Dual link
HDCP compliant
Length
20 cm
Connector
24+1 pin digital DVI - female
DisplayPort 1.1, FCC, RoHS
2 years warranty
7NZM StarTech.com 6 ft DVI-D Dual Link Cable - M/M In Stock £6.71
7NZM StarTech.com 10 ft DVI-D Dual Link Cable - M/M In Stock £10.60
7NZM StarTech.com Mini DisplayPort to DVI Active Adapter In Stock £21.76
Price Range Ex VAT: 0 - 50
