StarTech.com Mini 4 Port USB 2.0 Hub
Quicklinx: 5FRCWS00 Mfr#: ST4200MINI
Provides 4 external USB 2.0 ports in a compact and portable form factor. The ST4200MINI Mini 4 port USB hub allows you to turn a single USB connection into four USB ports, and based on a small form factor design, requires minimal space to install.
An ideal laptop accessory for maximizing the number of available USB device connections, the mini four port USB hub operates on low levels of power, helping to ensure that you get the most out of your notebook battery.
The mini four port hub supports Hi-speed USB 2.0 data transfers of up to 480 Mbps, and since the hub is backwards-compatible with previous versions of USB, your older USB peripherals will work perfectly as well.
StarTech.com Mini 4 Port USB 2.0 Hub - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB 2.0
9 cm x 2 cm x 1.3 cm
Apple MacOS X, Microsoft Windows 98 Second Edition / Windows ME, Microsoft Windows 2000 / XP
P/N: FCREADMICRO, USB56KEM, USB120EXT, USB110EXT, USB100EXT
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB 2.0
Status Indicators
4 x USB 2.0 Type A , 1 x USB 2.0 Type A
1 x USB cable
Plug and Play, FCC Class B certified
9 cm
2 cm
1.3 cm
StarTech.com 1 Port Cat5 USB Extender, External 56K USB Modem, USB Multi Media Memory Card Reader Adapter
5FRC StarTech.com Mountable 4 Port Rugged Industrial USB Hub In Stock £63.72
