Connect your USB On-the-Go capable tablet computer or Smartphone to USB 2.0 devices (thumb drives, USB mouse or keyboard, etc.). The UUSBOTGADAP USB OTG Adapter converts your Micro USB On-The-Go capable tablet computer or Smartphone into a USB OTG host by adding a USB port to your mobile digital device, which increases its functionality and enables you to use a USB peripheral such as a thumb drive, or a USB mouse or keyboard, etc.
This Micro USB OTG Adapter is constructed for maximum durability, to ensure dependable, long-lasting connections.
This adapter will only work with devices that support USB OTG. Please consult your documentation and/or your service provider to ensure that your device does support USB OTG functionality.
- StarTech.com Micro USB OTG to USB Adapter - Micro USB Male OTG to USB Female Adapter - USB On The Go Adapter (UUSBOTGADAP) - USB adapter - USB to Micro-USB Type B
- USB adapter
- Connector
- 4 pin USB Type A - female
- Connector (Second End)
- 5 pin Micro-USB Type B - male
- Black
- Limited lifetime warranty
- USB adapter
- Black
- Connector
