StarTech.com Micro SD to Micro USB / USB OTG Adapter Card Reader For Android Devices
Quicklinx: 9PS2WS00 Mfr#: MSDREADU2OTG
£7.86 ex VAT
£9.43 inc VAT
Connect a Micro SD card to your computer or OTG mobile device, through a USB or Micro USB port. The MSDREADU2OTG Micro SD to USB/Micro USB Adapter lets you turn a Micro SD card into an external USB storage solution that can interface with any USB-enabled computer or OTG-enabled device, such as Samsung Galaxy smartphones and tablets.
Expand the storage capabilities of your OTG-enabled smartphone or tablet, by creating an external storage device that you can also connect to your USB-enabled computer, and transfer files from one device to another with standard USB and Micro USB interface options.
Maximize portability by creating a compact, external storage solution that you can connect to your smartphone, tablet or laptop computer. For a hassle-free setup, the OTG adapter supports plug-and-play installation and is natively supported by any USB-enabled computer or any OTG-enabled mobile device.
StarTech.com Micro SD to Micro USB / USB OTG Adapter Card Reader For Android Devices (MSDREADU2OTG) - card reader - USB 2.0
Card reader - external
Supported Memory Cards
miniSD, microSD
Host Interface
USB 2.0
miniSD, microSD
Host Interface
USB 2.0
12 mm
40 mm
5 mm
4 g
Memory Card
(max)
Required Ports
1 x 4 pin USB Type A , 1 x 5 pin Micro-USB Type B
Linux, Microsoft Windows 2000, Apple MacOS X 10.6, Android, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Google Chrome OS, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Apple OS X 10.9 Mavericks, Microsoft Windows XP / 7 / 8 / 8.1 (32/64 bits)
FCC, RoHS
9PS2 StarTech.com 16 ft USB 2.0 Active Extension Cable - M/F In Stock £13.97
9PS2 StarTech.com Mountable 4 Port Rugged Industrial USB Hub In Stock £49.28
9PS2 StarTech.com 3.5in Drive Bay IDE to Single CF SSD Adapter Card Reader In Stock £16.70
9PS2 StarTech.com Mountable Rugged Industrial 7 Port USB Hub In Stock £64.39
9PS2 StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £3.85
9PS2 StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £1.27
9PS2 StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £3.59
9PS2 StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £74.07
9PS2 StarTech.com USB 3.0 Multi Media Flash Memory Card Reader In Stock £20.36
9PS2 StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 In Stock £30.50
9PS2 StarTech.com 5in Micro USB to USB OTG Host Adapter M/F In Stock £5.01
9PS2 StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - White In Stock £16.36
9PS2 StarTech.com USB 3.0 External Flash Multi Media Memory Card Reader - SDHC MicroSD In Stock £10.62
9PS2 StarTech.com 3.5in Front Bay 22-in-1 USB 2.0 Internal Multi Media Memory Card Reader - Black In Stock £12.18
9PS2 StarTech.com Micro SD to Micro USB / USB OTG Adapter Card Reader For Android Devices In Stock £7.86
Price Range Ex VAT: 0 - 50
