Connect a Micro SD card to your computer or OTG mobile device, through a USB or Micro USB port. The MSDREADU2OTG Micro SD to USB/Micro USB Adapter lets you turn a Micro SD card into an external USB storage solution that can interface with any USB-enabled computer or OTG-enabled device, such as Samsung Galaxy smartphones and tablets.
Expand the storage capabilities of your OTG-enabled smartphone or tablet, by creating an external storage device that you can also connect to your USB-enabled computer, and transfer files from one device to another with standard USB and Micro USB interface options.
Maximize portability by creating a compact, external storage solution that you can connect to your smartphone, tablet or laptop computer. For a hassle-free setup, the OTG adapter supports plug-and-play installation and is natively supported by any USB-enabled computer or any OTG-enabled mobile device.
- StarTech.com Micro SD to Micro USB / USB OTG Adapter Card Reader For Android Devices (MSDREADU2OTG) - card reader - USB 2.0
- Product Type
- Card reader - external
- Supported Memory Cards
- miniSD, microSD
- Host Interface
- USB 2.0
- Black
- 2-year warranty
- Product Type
- miniSD, microSD
- Host Interface
- USB 2.0
- Black
- 12 mm
- 40 mm
- 5 mm
- 4 g
Memory Card
- Capacity
- (max)
- Required Ports
- 1 x 4 pin USB Type A , 1 x 5 pin Micro-USB Type B
- OS Required
- Linux, Microsoft Windows 2000, Apple MacOS X 10.6, Android, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Google Chrome OS, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Apple OS X 10.9 Mavericks, Microsoft Windows XP / 7 / 8 / 8.1 (32/64 bits)
- FCC, RoHS
- Limited warranty - 2 years
StarTech.com 5ft Desktop USB Extension Cable - A Male to A Female | In Stock | £5.29 |
StarTech.com Mountable 4 Port Rugged Industrial USB Hub | In Stock | £63.72 |
StarTech.com 3.5in Drive Bay IDE to Single CF SSD Adapter Card Reader | In Stock | £19.71 |
StarTech.com Mountable Rugged Industrial 7 Port USB Hub | In Stock | £83.28 |
StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F | In Stock | £4.95 |
StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.17 |
StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.26 |
StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub | In Stock | £99.33 |
StarTech.com 6in USB 2.0 Extension Adapter Cable A to A - M/F | In Stock | £4.61 |
StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 | In Stock | £44.71 |
StarTech.com 5in Micro USB to USB OTG Host Adapter M/F | In Stock | £5.32 |
StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - White | In Stock | £21.33 |
StarTech.com USB 3.0 External Flash Multi Media Memory Card Reader - SDHC MicroSD | In Stock | £12.51 |
StarTech.com 3.5in Front Bay 22-in-1 USB 2.0 Internal Multi Media Memory Card Reader - Black | In Stock | £12.96 |
StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F | In Stock | £6.21 |
StarTech.com 1m White USB 2.0 Extension Cable A to A - M/F | In Stock | £5.82 |
