StarTech.com Micro HDMI to VGA Adapter Converter with Audio - 1920x1200
Quicklinx: 8Y6RWS00 Mfr#: MCHD2VGAA2
19 in stock
£24.56 ex VAT
£29.47 inc VAT
Convert a Micro HDMI video signal to VGA, with discrete audio output. The MCHD2VGAA2 Micro HDMI to VGA Video Adapter enables you to connect a Smartphone or tablet that outputs content through a Micro HDMI connector to a VGA-capable display device (television, monitor, projector), and also offers discrete 2-channel analog audio output from the Micro HDMI source. The Micro HDMI to VGA adapter is intended for displaying user generated content such as presentations, documents, and work sheets onto a VGA projector or monitor.
This versatile adapter supports high definition output, including 1080p for HDTV connections, and up to 1920x1200 (WUXGA) for computer VGA monitors.
StarTech.com Micro HDMI to VGA Adapter with Audio for Smartphones / Tablets - video converter - black
Video converter
Max Resolution
1920 x 1200
1 x HDMI input - 19 pin micro HDMI Type D , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm
4.5 cm x 25.8 cm x 1.5 cm
Enclosure Colour
3-year warranty
Video converter
Max Resolution
1920 x 1200
1 x HDMI input - 19 pin micro HDMI Type D - male , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female , 1 x audio line-out - mini-phone stereo 3.5 mm - female
UL, FCC, RoHS
4.5 cm
25.8 cm
1.5 cm
34 g
Enclosure Colour
Limited warranty - 3 years
60 °C
40 - 85% (non-condensing)
8Y6R StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.74
8Y6R StarTech.com 6 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £3.65
8Y6R StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.00
8Y6R StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £15.85
8Y6R StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £33.00
8Y6R StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.52
8Y6R StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.99
8Y6R StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.28
8Y6R StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male In Stock £4.31
8Y6R StarTech.com Micro HDMI to VGA Adapter Converter with Audio - 1920x1200 In Stock £24.56
Price Range Ex VAT: 0 - 50
