Convert a Micro HDMI video signal to VGA, with discrete audio output. The MCHD2VGAA2 Micro HDMI to VGA Video Adapter enables you to connect a Smartphone or tablet that outputs content through a Micro HDMI connector to a VGA-capable display device (television, monitor, projector), and also offers discrete 2-channel analog audio output from the Micro HDMI source. The Micro HDMI to VGA adapter is intended for displaying user generated content such as presentations, documents, and work sheets onto a VGA projector or monitor.
This versatile adapter supports high definition output, including 1080p for HDTV connections, and up to 1920x1200 (WUXGA) for computer VGA monitors.
- StarTech.com Micro HDMI to VGA Adapter Converter w/ Audio for Smartphones / Ultrabooks / Tablets 1920x1080 - Micro HDMI Male to VGA Female (MCHD2VGAA2) - video converter - black
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x HDMI input - 19 pin micro HDMI Type D , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm
- 4.5 cm x 25.8 cm x 1.5 cm
- Enclosure Colour
- Black
- 3-year warranty
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x HDMI input - 19 pin micro HDMI Type D - male , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female , 1 x audio line-out - mini-phone stereo 3.5 mm - female
- UL, FCC, RoHS
- 4.5 cm
- 25.8 cm
- 1.5 cm
- 34 g
- Enclosure Colour
- Black
- Limited warranty - 3 years
- 0 °C
- 60 °C
- 40 - 85% (non-condensing)
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £12.84 |
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M | In Stock | £31.26 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.94 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.82 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.73 |
StarTech.com 3 ft Stereo Audio Cable - 3.5mm Male to 2x RCA Male | In Stock | £5.00 |
