StarTech.com MHL Adapter Converter – Micro USB to HDMI
Quicklinx: 81T8WS00 Mfr#: MHD2HDF
Connect your MHL-enabled mobile device to an HDTV, monitor or projector using HDMI. The MHD2HDF MHL (Mobile High-Definition Link) Adapter - Micro USB to HDMI Active Video Adapter enables you to connect any MHL-enabled smartphone, tablet PC or other mobile device to non-MHL-enabled HDTVs, monitors or projectors through HDMI - a simple plug-and-play solution for viewing your photos and video (with supporting audio) and other mobile device content on a large display.
The MHL to HDMI adapter supports 1080p output resolution and 7.1 channel digital audio, to deliver on both quality and convenience.
This compact, active adapter offers a Micro USB port on the side, for the added benefit of simultaneously charging your connected mobile device, so it is always ready to use.
StarTech.com MHL Adapter Converter - Micro USB to HDMI - external video adapter - SiI9292CNUC - black
External video adapter
Bus Type
Mobile High-Definition Link (MHL) (5 pin Micro-USB)
Graphics Engine
SiI9292CNUC
Max Resolution
1920 x 1080
HDMI , USB 2.0 (power only)
2 cm 1 cm
Length
15 cm
Enclosure Colour
Bus Type
Graphics Engine
SiI9292CNUC
Max Resolution
1920 x 1080
USB powered
Plug and Play, FCC, RoHS
2 cm
1 cm
Length
15 cm
20 g
Enclosure Colour
45 °C
81T8 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.37
