Connect your MHL-enabled mobile device to an HDTV, monitor or projector using HDMI. The MHD2HDF MHL (Mobile High-Definition Link) Adapter - Micro USB to HDMI Active Video Adapter enables you to connect any MHL-enabled smartphone, tablet PC or other mobile device to non-MHL-enabled HDTVs, monitors or projectors through HDMI - a simple plug-and-play solution for viewing your photos and video (with supporting audio) and other mobile device content on a large display.
The MHL to HDMI adapter supports 1080p output resolution and 7.1 channel digital audio, to deliver on both quality and convenience.
This compact, active adapter offers a Micro USB port on the side, for the added benefit of simultaneously charging your connected mobile device, so it is always ready to use.
- StarTech.com MHL Adapter Converter - Micro USB to HDMI - external video adapter - SiI9292CNUC - black
- External video adapter
- Bus Type
- Mobile High-Definition Link (MHL) (5 pin Micro-USB)
- Graphics Engine
- SiI9292CNUC
- Max Resolution
- 1920 x 1080
- HDMI , USB 2.0 (power only)
- 2 cm 1 cm
- Length
- 15 cm
- Enclosure Colour
- Black
- 2-year warranty
- Bus Type
- Graphics Engine
- SiI9292CNUC
- Max Resolution
- 1920 x 1080
- USB powered
- Plug and Play, FCC, RoHS
- 2 cm
- 1 cm
- Length
- 15 cm
- 20 g
- Enclosure Colour
- Black
- Limited warranty - 2 years
- 0 °C
- 45 °C
