Connect your Mac or PC to a VGA display and a discrete 3.5mm audio output. This unique Mini DisplayPort to VGA adapter is equipped with a built-in audio port which lets you connect Mini DisplayPort equipped devices, such as a Microsoft Surface Pro 3 tablet or MacBook Air laptop, to a VGA display or projector with audio.
Because most boardrooms are set up differently, the length of cables available in each room vary. Not all laptops have the Mini DisplayPort (mDP) and audio ports positioned on the same side, which can become awkward when you're trying to share your presentations. It can also mean that some ports may be just out of reach during a meeting.
This convenient adapter positions your audio and video ports on the same side of your laptop, to ensure that all of the ports you need are accessible when you need them.
If the audio port on your mobile device is damaged or blocked by other connections, this convenient adapter guarantees that you'll always have all of the ports you need for every presentation. By connecting audio to your laptop through the adapter, you can be prepared for any situation.
In order to use the audio function of the adapter you need to power the adapter through a USB port on your laptop, or through a charge port on a USB grommet. Simply plug a Micro USB cable from the adapter into the USB port and audio will be available when you deliver your presentation.
The adapter can also be used for connecting your laptop or desktop computer to your monitor and speakers. The adapter and connected cables can be placed nicely at the back of your monitor to create a tidy setup between all of your devices.
This mDP to VGA adapter is extremely portable with a lightweight, small-footprint design. It's the perfect accessory to carry with your mobile devices, fitting easily into your laptop bag or carrying case. Its ultra-portable design makes the adapter ideal for BYOD (Bring Your Own Device) applications at the office.
It also enables you to arrive prepared when you're presenting to a potential client, teaching off-site, or traveling to a meet with a customer.
The adapter is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port, and supports resolutions up to 1920x1200 (WUXGA).
- StarTech.com Mini DisplayPort to VGA Adapter with Audio - Mini DP to VGA Converter - 1920x1200 (MDP2VGAA) - video converter - black
- Video converter
- Max Resolution
- 1920 x 1080
- 1 x DisplayPort input - Mini DisplayPort , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x USB - 5 pin Micro-USB Type B (power only) , 1 x audio line-out - mini-phone stereo 3.5 mm
- Enclosure Colour
- Black
- 3-year warranty
- Video converter
- Max Resolution
- 1920 x 1080
- 1 x DisplayPort input - Mini DisplayPort - male , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female , 1 x USB - 5 pin Micro-USB Type B (power only) - female , 1 x audio line-out - mini-phone stereo 3.5 mm - female
- USB powered
- Cables Included
- 1 x micro-USB cable - 25 cm
- FCC, RoHS
- 60 g
- Enclosure Colour
- Black
- Limited warranty - 3 years
- 0 °C
- 70 °C
StarTech.com Mini DisplayPort to VGA Video Adapter Converter | In Stock | £17.29 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £15.98 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter - White | In Stock | £10.89 |
StarTech.com Mini DisplayPort to HDMI Video Adapter Converter - White | In Stock | £10.50 |
StarTech.com Mini DisplayPort to VGA Video Adapter Converter - White | In Stock | £15.54 |
StarTech.com Mini DisplayPort 1.2 to VGA Adapter Converter – Mini DP to VGA – 1920x1200 | In Stock | £15.14 |
StarTech.com mDP to VGA Adapter with Audio | In Stock | £18.78 |
