Connect your mDP computer directly to a DVI display, using this two-piece kit. This Mini DisplayPort connectivity kit gives you everything you need to connect your Mini DisplayPort (mDP) computer to your DVI monitor, up to 6 ft. away.
The two-piece kit includes an active mDP to HDMI converter (MDP2HD4KS), and a 6 ft. HDMI to DVI adapter cable (HDMIDVIMM6), which you can use together to create a seamless mDP to DVI connection.
Unlike passive video adapters, the Mini DisplayPort to HDMI converter that's included in this kit provides an active conversion that you can use with any Mini DisplayPort output. It's perfect for devices that require active adapters, such as the Microsoft Surface Pro 3 docking station, because it delivers an active mDP to DVI connection.
This two-piece kit gives you an easy way to connect your mDP devices to a DVI monitor, without having to install any drivers, and also gives you the option to connect an HDMI display instead, using an HDMI cable (sold separately).
The included mDP to HDMI converter is also compatible with Intel Thunderbolt devices that output a DisplayPort video signal.
Active conversion, broader compatibility
Unlike passive video adapters, the Mini DisplayPort to HDMI converter that's included in this kit provides an active conversion that you can use with any Mini DisplayPort output. It's perfect for devices that require active adapters, such as the Microsoft Surface Pro 3 docking station, because it delivers an active mDP to DVI connection. -
Easy installation, convenient connectivity
This two-piece kit gives you an easy way to connect your mDP devices to a DVI monitor, without having to install any drivers. The included mDP to HDMI converter is also compatible with Intel Thunderbolt devices that output a DisplayPort video signal.
- StarTech.com 2-Piece Kit - Active mDP to HDMI Adapter and HDMI to DVI Cable - video converter
- Video converter
- 1 x DisplayPort input - Mini DisplayPort , 1 x HDMI output - 19 pin HDMI Type A , 1 x DVI-D output - 18+1 pin digital DVI (Single-Link) (on supplied cable)
- 3-year warranty
- Video converter
- 1 x DisplayPort input - Mini DisplayPort - male , 1 x HDMI output - 19 pin HDMI Type A - female , 1 x DVI-D output - 18+1 pin digital DVI (Single-Link) (on supplied cable) - male
- Cables Included
- 1 x HDMI-DVI cable - 1.83 m
- Limited warranty - 3 years
StarTech.com Mini DisplayPort to DVI Video Adapter Converter | In Stock | £11.09 |
StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M | In Stock | £26.80 |
StarTech.com Mini DisplayPort to DVI Video Adapter Converter - Black Mini DP to DVI - 1920x1200 | In Stock | £11.09 |
StarTech.com 6 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black | In Stock | £14.80 |
StarTech.com 6 ft Mini DisplayPort to DVI Active Adapter Converter Cable - 2560x1600 – Black | In Stock | £24.24 |
