StarTech.com M.2 PCIe Adapter w/ Chassis
Quicklinx: DXG8WS00 Mfr#: BNDTB4M2E1
The Thunderbolt 3 m.2 enclosure lets you take advantage of the speed and size of PCIe M.2 internal solid-state drives, connected externally to your Thunderbolt 3 desktop or laptop computer. This Thunderbolt 3 to PCIe M.2 adapter lets you take advantage of the speed of PCIe solid-state drives, connected externally to your Thunderbolt 3 desktop or laptop computer. The adapter combines the StarTech.com Thunderbolt 3 PCIe Expansion Chassis (TB31PCIEX16) and the M.2 PCIe SSD adapter card (PEX4M2E1), giving you a DisplayPort output and an additional Thunderbolt 3 port.
Get ultra-fast data access by adding this PCIe M.2 SSD adapter externally to your existing Thunderbolt 3 computer, using the Thunderbolt 3 chassis - improving your storage performance and expanding overall capacity. The adapter supports PCIe M.2 SSDs (NVMe and AHCI): 2242, 2260, 2280, and 22110 drives.
Connect additional displays through the chassis' dedicated DisplayPort output and second Thunderbolt 3 (USB-C) port (USB-C video adapter may be required). With two extended displays, you can multitask effortlessly, avoiding the hassle of repositioning open windows or programs repeatedly throughout your workday.
You can assemble and connect the adapter in minutes. Put it together using only a screwdriver then plug and play with no software or drivers required.
StarTech.com Thunderbolt 3 to PCIe M.2 adapter - Chassis + Card - interface adapter - M.2 Card - PCIe x4
Interface adapter - plug-in card - low profile
Bundled with
Thunderbolt 3 PCIe Expansion Chassis (TB31PCIEX16) with DisplayPort
Bus Type
PCIe x4
Supported Form Factor
Expansion Slot to M.2
Expansion Bays
1 x internal - M.2
Hard Drive Form Factor Compatibility
M.2
M.2 Card
Supported Devices
Solid state drive
M.2
Bundled with
Host Bus
PCIe x4
Storage Controller
M.2 Card
Supported Devices
Solid state drive
Bays
1 x internal - M.2
Low-profile bracket, full-profile bracket
FCC, RoHS, WEEE, RCM
5 °C
50 °C
15 - 90%
DXG8 StarTech.com M.2 NGFF to SATA SSD adapter In Stock £13.39
DXG8 StarTech.com 4x M.2 to SATA 3.5in adapter In Stock £34.68
DXG8 StarTech.com 2x M.2 SSD Controller - PCIe In Stock £47.74
