StarTech.com M.2 NGFF to SATA SSD adapter
Quicklinx: B3B1WS00 Mfr#: S32M2NGFFPEX
Compatibility: Mac, PC
£13.25 ex VAT
£15.90 inc VAT
Mount a solid state drive into your desktop computer, using a standard SATA host connection. The SAT32MSATPEX M.2 to SATA adapter lets you connect a SATA M.2 (NGFF) SSD to a standard SATA port, and mount the drive into any desktop expansion slot.
Now, you can greatly increase the performance of your desktop computer by replacing your platter drive with a fast M.2 NGFF solid state drive. By installing your primary operating system on the M.2 SSD drive and using your higher-capacity platter HDD for bulk storage, you can harness the speedy performance of the M.2 drive for frequently accessed data while storing files you access less often on your platter drive.
For a hassle-free installation, the adapter mounts into any new or legacy desktop expansion slot, with support for AGP, PCI, and PCIe slots. The adapter also includes full-profile and low-profile brackets, ensuring compatibility with both full-sized and small form factor desktops.
StarTech.com M.2 to SATA SSD adapter - storage controller (RAID) - SATA 6Gb/s - SATA 6Gb/s
Storage controller (RAID) - internal
Bus Type
SATA 6Gb/s
Compatible Bay
1
Hard Drive Form Factor Compatibility
M.2
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
12 cm x 9.5 cm x 1.8 cm
130 g
M.2
Host Bus
SATA 6Gb/s
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Solid state drive
1 x M.2 Card - M.2 Card
1 x SATA 6Gb/s - 22 pin Serial ATA
Compatible Bay
1 x internal
Low-profile bracket, screwdriver, 1 x screw
FCC, RoHS
12 cm
9.5 cm
1.8 cm
130 g
50 °C
5 - 95%
B3B1 StarTech.com 12in Latching SATA Cable In Stock £3.33
B3B1 StarTech.com SATA to LP4 Power Cable Adapter In Stock £4.35
B3B1 StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F In Stock £4.32
B3B1 StarTech.com 12in LP4 to 2x Latching SATA Power Y Cable Splitter Adapter - 4 Pin Molex to Dual SATA In Stock £3.79
B3B1 StarTech.com 12in LP4 to 2x Right Angle Latching SATA Power Y Cable Splitter - 4 Pin Molex to SATA In Stock £3.87
B3B1 StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F In Stock £4.44
B3B1 StarTech.com 12in SATA Serial ATA Cable In Stock £3.05
Compatibility: Mac
Compatibility: PC
Price Range Ex VAT: 0 - 50
