This LP4 to SATA Power Adapter Cable features an LP4 female connector as well as an SP4 female power connector and a SATA power connector, allowing you to connect an IDE hard drive as well as a floppy disk drive to a Serial ATA power connector provided by the computer power supply. This high quality LP4/SATA power adapter cable is expertly designed for durability.
- StarTech.com LP4 to SATA Power Cable Adapter with Floppy Power - power adapter
- Power adapter
- Connectors
- 15 pin Serial ATA power - male
- Connectors (Second End)
- 4 PIN internal power - female , 4 PIN mini-power connector - female
- Black
- Limited lifetime warranty
- Designed For
- P/N: SATSASBAY425, ATX2POWER430, ATX2POWER530, DRW110SATBK
- Power adapter
- Black
- Connectors
- Designed For
- StarTech.com 4 Drive 2.5in Removable SAS SATA Mobile Rack Backplane, 430 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC, 530 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC
StarTech.com LP4 to SATA Power Cable Adapter with Floppy Power | In Stock | £5.10 |
StarTech.com SATA to LP4 Power Cable Adapter with 2 Additional LP4 | In Stock | £4.53 |
StarTech.com 6in LP4 to LP4 SATA Power Y Cable Adapter | In Stock | £3.30 |
