Charge or sync your Micro USB, iPhone, iPod or iPad device using a single cable. Tired of carrying around multiple cables for charging and syncing your different mobile devices?
This convenient 2-in-1 cable lets you charge and sync either your Apple Lightning equipped devices or your Android mobile devices, through an available USB port on your PC or Mac computer.
Offering both a Lightning connector for your iPhone, iPod or iPad and a Micro USB connector for your Android phone or tablet, this is the perfect cable for all your mobile charging needs.
The LTUB1MWH white 2-in-1 charge-and-sync cable is Apple MFi certified.
- StarTech.com 1m (3ft) Apple Lightning or Micro USB to USB Cable for iPhone / iPod / iPad - White - Apple MFi Certified (LTUB1MWH) - charging / data cable - Lightning / USB - 1 m
- Cable
- Charging / data cable - Lightning / USB
- Technology
- Shielded
- American Wire Gauge (AWG)
- 24/28
- Length
- 1 m
- White
- Connectors
- USB - male
- Connectors (Second End)
- Micro-USB Type B - male , Lightning - male
- 2-year warranty
- Designed For
- P/N: HB30C4AFS
- Cable Type
- Interface Supported
- Lightning / USB
- Technology
- Shielded
- 24/28
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 1 m
- Plated Connector
- Nickel
- White
- Connectors
- 4 pin USB Type A - male
- 5 pin Micro-USB Type B - male , Apple Lightning - male
- MFI
- Limited warranty - 2 years
- Designed For
- P/N: HB30C4AFS
