Use this USB crash-cart adapter to turn your laptop into a portable KVM console for accessing servers, ATMs and kiosks with file transfer and video capture. This rugged and portable USB crash cart adapter lets you turn your laptop into a portable console for accessing servers, desktops and laptops, as well as ATMs, kiosks or any computing device that features both VGA and USB ports.
This adapter also supports local file transfer and video capturing built into the software.
This crash cart adapter has been specifically designed for maximum durability. It features a rugged, rubberized housing that can handle drops by absorbing shock, to make sure that you're equipped for unexpected challenges.
Troubleshoot your devices quickly and easily. Simply connect the crash cart adapter to your laptop using the included USB cable, then connect the integrated USB and VGA cables to your server.
The crash cart adapter features a flexible software interface that offers robust performance. It enables you to transfer files from your laptop to the server, monitor and capture activity from the connected device as video for records or instructional purposes, and take screenshots and scale the display window to full-screen mode or smaller, without scroll bars.
This compact crash cart adapter lets you connect to a headless device using only a laptop, eliminating the need to lug around an awkward, traditional server room crash cart. With optimal portability in mind for your mobile administration or repairs, this pocket-sized adapter features a small footprint and lightweight design that easily fits inside your laptop bag.
The adapter is USB powered so you won't need to carry a power adapter. Plus, the KVM cables are attached to the crash cart adapter so you won't need additional accessories to connect it to your server. The built-in cables have been engineered with strain relief, preventing them from wearing or breaking.
With no server-side software installation required, the USB crash cart adapter provides BIOS-level control of any PC or device that has both a VGA port and a USB port.
Maximum durability
This crash cart adapter has been specifically designed for maximum durability. It features a rugged, rubberized housing that can handle drops by absorbing shock, to make sure that you're equipped for unexpected challenges. -
Hassle-free operation
Troubleshoot your devices quickly and easily. Simply connect the crash cart adapter to your laptop using the included USB cable, then connect the integrated USB and VGA cables to your server. The crash cart adapter features a flexible software interface that offers robust performance. It enables you to transfer files from your laptop to the server, monitor and capture activity from the connected device as video for records or instructional purposes, and take screenshots and scale the display window to full-screen mode or smaller, without scroll bars. -
Compact portability
This compact crash cart adapter lets you connect to a headless device using only a laptop, eliminating the need to lug around an awkward, traditional server room crash cart. With optimal portability in mind for your mobile administration or repairs, this pocket-sized adapter features a small footprint and lightweight design that easily fits inside your laptop bag. The adapter is USB powered so you won't need to carry a power adapter. Plus, the KVM cables are attached to the crash cart adapter so you won't need additional accessories to connect it to your server. The built-in cables have been engineered with strain relief, preventing them from wearing or breaking. -
Universal connectivity
With no server-side software installation required, the USB crash cart adapter provides BIOS-level control of any PC or device that has both a VGA port and a USB port. The NOTECONS02X is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com USB Crash Cart Adapter with File Transfer and Video Capture - Laptop to Server KVM Console - Portable & Rugged (NOTECONS02X) - KVM switch - 1 ports
- Subtype
- KVM
- Ports
- 1 x KVM port(s)
- KVM Users Qty
- 1 local user
- USB powered
- 7.4 cm x 11.5 cm x 1.5 cm
- 170 g
- Black
- System Requirements
- Microsoft Windows Server 2008 R2, Linux 2.6 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.9 - 10.15, Apple macOS 11.0, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 1 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1920 x 1200 @ 60 Hz
- USB powered
- Status Indicators
- Link/activity
- 1 x mini-USB 2.0 Type B , 1 x USB 2.0 Type A , 1 x VGA HD-15
- Black
- Cables Included
- 1 x USB host cable - 38.5 cm , 1 x USB cable - 1.8 m , 1 x VGA cable - 7.6 cm
- FCC, RoHS
- OS Required
- 7.4 cm
- 11.5 cm
- 1.5 cm
- 170 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
StarTech.com KVM Console to USB 2.0 Portable Laptop Crash Cart Adapter | In Stock | £384.36 |
StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 | In Stock | £25.58 |
StarTech.com KVM Console to Laptop USB 2.0 Portable Crash Cart Adapter with File Transfer | In Stock | £422.79 |
StarTech.com Laptop to Server KVM Console | In Stock | £477.02 |
StarTech.com 17.3" Laptop Backpack w/ Case | In Stock | £105.68 |
