Adjust the height and tilt of a laptop to eye level for ergonomic comfort and increased productivity. The laptop riser stand supports any laptop with a maximum weight capacity of 22lb (10kg). The lightweight and foldable design enables quick transportation and convenient storage. When collapsed, the riser measures 10.6x8.8x1.9in (27x22.5x5cm). The laptop riser for desks ships fully assembled for immediate use.
Tilt for Ideal Viewing
This ergonomic laptop stand features tilt and height adjustments (up to 4.7in/12cm) to establish the most comfortable viewing angle. Adjust the tension of the support arms, using the included tool, for various weight, tilt, and height settings. The raised flanges (0.7in /18mm), located at the front of the laptop platform, ensure the laptop remains in place when the platform is tilted. Rubber pads around the surface help protect the laptop from cosmetic damage. -
Stable Laptop Stand
The laptop riser features a silver anodized finish with aluminum construction to ensure durability and sturdiness. The vented surface area is elevated to promote passive cooling and airflow. The space underneath the laptop platform can be used to store a keyboard, mouse, and/or other accessories and peripherals when they are not in use. The non-skid rubber feet aid in protecting the surface of the desk from scratches and scuffs, including glass top desks. This product is backed for two years, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com Laptop Stand for Desk, Ergonomic Laptop Stand Adjustable Height, Aluminum, Portable, Supports up to 22lb (10kg), Foldable Laptop Holder for Desk - Angled Notebook Computer Riser/Lift (ADJ-LAPTOP-RISER) - notebook stand
- Product Type
- Notebook stand
- Placing / Mounting
- Desk mountable
- Package Content
- Notebook riser
- Silver
- Product Material
- Aluminium
- 22.6 cm x 26.9 cm x 5 cm
- 700 g
- Ergonomic
- 5-year warranty
- Designed For
- P/N: PRIVSCNLT15, PRIVSCNMAC13, PRIVSCNMAC15
- Product Type
- Notebook stand
- Desk mountable
- Product Material
- Aluminium
- Package Content
- Notebook riser
- 22.6 cm
- 26.9 cm
- 5 cm
- Max Load Weight
- 10 kg
- 700 g
- Shipping Dimensions (WxDxH) / Weight
- 23.5 cm x 28 cm x 6 cm / 0.9 kg
- Silver
- Ergonomic
- Limited warranty: - 5 years
- Designed For
StarTech.com 15in Laptop Privacy Screen - Matte or Glossy - 16:9 Ratio | In Stock | £31.60 |
StarTech.com 13in Laptop Privacy Screen - 16:10 Aspect Ratio | In Stock | £32.64 |
