StarTech.com Laptop Lock - 6' Steel Cable
Quicklinx: D8K5WS00 Mfr#: LTLOCK
Type: Security
More than 50 in stock
£15.42 ex VAT
£18.50 inc VAT
Protect your laptop against theft with this convenient combination lock. This laptop lock gives you an easy and effective way to secure your laptop to a sturdy object and keep it safe from theft. With this 4-digit combination lock, you can be confident your laptop and valuable data are well protected.
You can ensure that your laptop, monitor, docking station or other electronic device will be anchored safely to your workspace in just a few simple steps with this keyless 4-digit combination lock. It effortlessly latches directly into any laptop or other device equipped with a built-in security-lock slot, providing dependable theft prevention in a wide range of retail, commercial, and institutional environments.
Featuring a vinyl-coated steel cable (6 mm diameter), this laptop lock is designed for effective theft prevention.
StarTech.com Laptop Lock security cable lock
Security cable lock
Black & silver
Product Material
Vinyl, steel
0.6 cm 0.6 cm
Length
1.8 m
182 g
Security cable lock
Product Material
Vinyl, steel
0.6 cm
0.6 cm
Length
1.8 m
182 g
Black & silver
StarTech.com Laptop Lock - 6' Steel Cable Bundle deal on StarTech.com Laptop Lock - 6' Steel Cable
£114.59
D8K5 StarTech.com Universal USB 3.0 Laptop Docking Station Dual-Monitor HDMI DVI In Stock £102.22
D8K5 StarTech.com Universal USB 3.0 Laptop Docking Station - Dual Video HDMI DVI VGA with Audio In Stock £90.65
Type: Security
Price Range Ex VAT: 0 - 50
