StarTech.com KVM Console to Laptop USB 2.0 Portable Crash Cart Adapter with File Transfer
Quicklinx: 9G6JWS00 Mfr#: NOTECONS02
Type: KVM switch
Connectivity: KVM
Ports: 1
  • Windows 8 (32/64 bits)
Hurry, only 2 left in stock!
£324.53 ex VAT
£389.43 inc VAT
The NOTECONS02 Portable USB Crash Cart Adapter lets you turn your laptop into a portable console for rack servers, PCs, ATMs, kiosks and more, now with local file transfer built-in. Simply connect the crash cart adapter to your laptop using the included USB cable, then connect the integrated USB and VGA cables to your server for instant, BIOS-level control.
Get connected in seconds. The crash cart adapter offers integrated VGA and USB cables for the server-side connections and includes the USB cable to connect to your laptop.
Troubleshoot your devices faster with a flexible software interface that lets you transfer files from your laptop to the server, take screenshots and scale the display window to full screen mode or smaller, with no scroll bars - ever.
With no server-side software installation required, the USB crash cart adapter can connect to any PC or device that has a VGA and USB port, to provide BIOS-level control.
Powered from the server-side USB connection, the laptop crash cart adapter doesn't require an AC outlet and saves your laptop / netbook battery power.
With portability for the mobile administrator or repair technician in mind, this pocket-sized adapter features a rugged design that easily fits inside your laptop bag and requires no additional accessories to connect.
Eliminating the need to lug around a large, awkward traditional crash cart to troubleshoot and service your systems, this portable crash cart lets you connect to a headless device with only a laptop.
StarTech.com USB Crash Cart Adapter with File Transfer & Video Capture - KVM switch - 1 ports
Subtype
KVM
Ports
1 x KVM port(s)
KVM Users Qty
1 local user
Firmware upgradable
7.4 cm x 11.5 cm x 1.5 cm
170 g
Apple MacOS X 10.x, Linux 2.6.x or later, Microsoft Windows Server 2008 R2, Microsoft Windows Vista / 2000 / XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Enclosure Type
Desktop
Subtype
KVM
Ports
1 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1200 @ 60 Hz
Firmware upgradable
Status Indicators
Link/activity
2 x USB 2.0 Type A , 1 x VGA HD-15
1 x USB host cable - 38.5 cm , 1 x USB cable - 1.8 m , 1 x VGA cable - 7.6 cm
FCC, RoHS
7.4 cm
11.5 cm
1.5 cm
170 g
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
9G6J StarTech.com DVI to VGA Cable Adapter - M/F In Stock £4.87
9G6J StarTech.com 6 ft Mini USB Cable - A to Mini B In Stock £3.17
9G6J StarTech.com 3 ft Mini USB 2.0 Cable - A to Mini B In Stock £3.18
9G6J StarTech.com 10 ft USB 2.0 Cable - USB A to Mini B In Stock £3.31
Type: KVM switch
Connectivity: KVM
Ports: 1
Price Range Ex VAT: 300 - 500
