StarTech.com Juniper SFP-GE40KT15R13 Comp SFP SM Module - 1000Base-BX40-D
Quicklinx: FJNWWS00 Mfr#: SFPGE40KT5R3
The SFPGE40KT5R3 is a Juniper SX compatible fiber transceiver module that has been designed, programmed and tested to work with Juniper brand switches and routers. It delivers dependable 1 GbE connectivity over fiber cable, for 1000Base-BX40-D compliant networks, with a maximum distance of up to 2 km (1.2 mi).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Juniper SFP-GE40KT15R13 Compatible SFP Module, 1000BASE-BX-D, 1 Gigabit Ethernet Bi-Directional (BiDi) Fiber Single Strand SFP, LC 40km, Mini GBIC Transceiver SFP, Upstream - Lifetime Warranty (SFPGE40KT5R3) - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-BX40-D
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 (TX) / 1550 (RX) nm
GigE
Max Transfer Distance
40 km
1.4 cm x 6.5 cm x 1.2 cm
72 g
Plug-in module
Wired
Cabling Type
1000Base-BX40-D
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
40 km
Full duplex mode, Digital Diagnostics Monitoring (DDM)
1 x Ethernet 1000Base-BX40-D - LC single-mode female
MTBF
3,713,222 hours
FCC, RoHS, REACH, MSA
1.6 Watt
1.4 cm
6.5 cm
1.2 cm
72 g
Shipping Width
20.7 cm
Shipping Depth
23 cm
Shipping Height
1.5 cm
Shipping Weight
80 g
Limited warranty - lifetime
