The SFPGE40KT3R5 is a Juniper SFPP-10GE-SR compatible fiber transceiver module that has been designed, programmed and tested to work with Juniper brand switches and routers. It delivers dependable 1 GbE connectivity over fiber cable, for 1000Base-BX40-U compliant networks, with a maximum distance of up to 40 km (24.8 mi).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com Juniper SFP-GE40KT13R15 Compatible SFP Module, 1000BASE-BX-U, 1 Gigabit Ethernet Bi-Directional (BiDi) Fiber Single Strand SFP, LC 40km, Mini GBIC Transceiver SFP, Upstream - Lifetime Warranty (SFPGE40KT3R5) - SFP (mini-GBIC) transceiver module - GigE
- SFP (mini-GBIC) transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-BX40-U
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 1310 (TX) / 1550 (RX) nm
- Data Link Protocol
- GigE
- Max Transfer Distance
- 40 km
- OEM Manufacturer Equivalent Part Number
- Juniper SFPP-10GE-SR
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-BX40-U
- GigE
- 1 Gbps
- 40 km
- Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 1000Base-BX40-U - LC single-mode female
- MSA
- 1.6 Watt
- Limited warranty - lifetime
