StarTech.com Juniper SFP-GE10KT15R13 Comp SFP SM Module - 1000Base-BX10-D
Quicklinx: FJNVWS00 Mfr#: SFPGE10KT5R3
17 in stock
£86.04 ex VAT
£103.24 inc VAT
The SFPGE10KT5R3 is a Juniper SFPP-10GE-LR compatible fiber transceiver module that has been designed, programmed and tested to work with Juniper brand switches and routers. It delivers dependable 1 GbE connectivity over fiber cable, for 1000Base-BX10-D compliant networks, with a maximum distance of up to 40 km (24.8 mi).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Juniper SFP-GE10KT15R13 Compatible SFP Module - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-BX10-D
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 (TX) / 1550 (RX) nm
GigE
Max Transfer Distance
10 km
1.4 cm x 6.5 cm x 1.2 cm
72 g
3-year warranty
Plug-in module
Wired
Cabling Type
1000Base-BX10-D
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
10 km
Full duplex mode, Digital Diagnostics Monitoring (DDM)
1 x Ethernet 1000Base-BX10-D - LC single-mode female
MTBF
3,713,222 hours
FCC, RoHS, REACH, MSA
1.3 Watt
1.4 cm
6.5 cm
1.2 cm
72 g
Shipping Width
20.7 cm
Shipping Depth
23 cm
Shipping Height
1.5 cm
Shipping Weight
80 g
Limited warranty - 3 years
Price Range Ex VAT: 50 - 100
