StarTech.com Juniper SFP-GE10KT14R13 Comp SFP SM Module - 1000Base-BX10-D
Quicklinx: FJNXWS00 Mfr#: SFPGE10KT4R3
The SFPGE10KT4R3 is a Juniper SFPP-10GE-LRM compatible fiber transceiver module that has been designed, programmed and tested to work with Juniper brand switches and routers. It delivers dependable 1 GbE connectivity over fiber cable, for 1000Base-BX10-D compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Juniper SFP-GE10KT14R13 Compatible SFP Module, 1000BASE-BX-D, 1 Gigabit Ethernet Bi-Directional (BiDi) Fiber Single Strand SFP, LC 10km, Mini GBIC Transceiver SFP, Downstream - Lifetime Warranty (SFPGE10KT4R3) - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-BX10-D
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 (TX) / 1490 (RX) nm
GigE
Max Transfer Distance
10 km
1.4 cm x 6.5 cm x 1.2 cm
72 g
Plug-in module
Wired
Cabling Type
1000Base-BX10-D
GigE
Data Transfer Rate
1 Gbps
Optical Wave Length
10 km
Full duplex mode, Digital Diagnostics Monitoring (DDM)
1 x Ethernet 1000Base-BX10-D - LC single-mode female
MTBF
3,713,222 hours
FCC, RoHS, REACH, MSA
1.3 Watt
1.4 cm
6.5 cm
1.2 cm
72 g
Shipping Width
20.7 cm
Shipping Depth
23 cm
Shipping Height
1.5 cm
Shipping Weight
80 g
Limited warranty - lifetime
