The SFPFE20KT3R5 is a Juniper SFP-GE10KT14R13 compatible fiber transceiver module that has been designed, programmed and tested to work with Juniper brand switches and routers. It delivers dependable 100 MbE connectivity over fiber cable, for 100Base-BX10-U compliant networks, with a maximum distance of up to 20 km (12.4 mi).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com Juniper SFP-FE20KT13R15 Compatible SFP Module, 100BASE-BX-U, 100 Mb Ethernet Bi-Directional (BiDi) Fiber Single Strand SFP, LC Connector, 20km, Mini GBIC SFP, Upstream BiDi - Lifetime Warranty (SFPFE20KT3R5) - SFP (mini-GBIC) transceiver module - 100Mb LAN
- SFP (mini-GBIC) transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 100Base-BX10-U
- Data Transfer Rate
- 100 Mbps
- Optical Wave Length
- 1310 (TX) / 1550 (RX) nm
- Data Link Protocol
- 100Mb LAN
- Max Transfer Distance
- 20 km
- OEM Manufacturer Equivalent Part Number
- Juniper SFP-GE10KT14R13
- 1.4 cm x 6.5 cm x 1.2 cm
- 72 g
- 3-year warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 100Base-BX10-U
- 100Mb LAN
- 100 Mbps
- 20 km
- Full duplex mode, Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 100Base-BX10-U - LC single-mode female
- MTBF
- 3,713,222 hours
- FCC, RoHS, REACH, MSA
- 1.4 cm
- 6.5 cm
- 1.2 cm
- 72 g
- Shipping Width
- 20.7 cm
- Shipping Depth
- 23 cm
- Shipping Height
- 1.5 cm
- Shipping Weight
- 80 g
- Limited warranty - 3 years
